Old 08-25-2010, 12:16 AM   #1
MonaxLisa's Avatar
1975 31' Excella 500
undetermined , Washington
Replacing the...thing
Does anyone know how I can replace this?
Sorry it's blurry.
It got broke when the I got locked in. Yeah, I know what you're thinking because I thought the same thing when the last owner told me the screen in one of the windows was gone because he got locked in and had to crawl out. "What kind of idiot gets locked inside?!"
So anyhow, at this point (which is odd because it was fine to begin with) the door doesnt lock...and it doesnt really stay shut. Well it does, but if you put pressure on it it pops open. So I figure if I replace that thing (which is confusing...it's riveted on...) with a thing that is thinner, it would stay shut and have less chance of getting locked in. It's weird because I used the door for like a month before it decided to stick shut. The handle turned and the door moved but something in there was stuck. Anyhow, really need to replace it, no idea how, help!
MonaxLisa is offline   Reply With Quote
Old 08-25-2010, 12:59 AM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, this looks like a door latch "striker plate" and you drill out the two pop rivets and replace it with a new striker plate and pop rivets. But I don't know why you got locked in.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-25-2010, 01:53 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
You can get a new one from Inland RV.
Old 08-25-2010, 03:36 AM   #4
Sorry it's blurry.
That part is a cast stainless steel striker pocket. It also uses a small brass shim.
It's replaced by drilling out those 2 rivets.
Old 08-25-2010, 09:07 PM   #5
MonaxLisa's Avatar
How do you drill out rivets? And how do you replace them?
Old 08-25-2010, 09:13 PM   #6
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
You use a 1/8" drill bit to take them out & replace them with 1/8" rivets & a rivet gun. To drill them out, you center the drill bit in the hole & drill. The outside part will come off (probably on your drill bit) and the center will fall down into the oblivion of the trailer wall. You're gonna need a rivet gun if you have an Airstream!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-25-2010, 10:22 PM   #7
Ottawa , ON
This operation requires a "pop" rivet tool and rivets. That is an inexpensive tool, and the rivets are easy to put in. They are mostly used on interior fastenings.
The solid, large ones on the outside are another matter. They are a different procedure, and require an air-powered rivet gun, and something called a "bucking" bar. An alternative to them is a tpe of rivet called and Olympic rivet, which is a pop rivet with a head that needs to be "shaved" down, and will resemble a bucked rivet when done.
Try a pop rivet first, you'll see how simple and easy it is.
ps: regarding blurry pictures: many folks don't realize that most digital cameras today can do clear close-ups: look for a button on it that has a little flower symbol. Press that button it before shooting close shots. It makes a wonderful difference!
Old 08-26-2010, 12:02 PM   #8
MonaxLisa's Avatar
My camera takes good closeups, I just didnt bother since it was late and dark
Old 08-26-2010, 12:03 PM   #9
MonaxLisa's Avatar
Ok, so if I replace this myself do you guys think I can replace it with something else? Like a regular door one? I don't want one that's as thick because I'm hoping if I get one thinner I wont risk getting locked in (I'm guessing that had something to do with the door...bolt thing didnt pull back quite all the way and got stuck on the striker plate)
Old 08-26-2010, 01:19 PM   #10
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
undetermined washington
well, I do not know where "undetermined" is located. If you are anywhere near Battle Ground, WA, (Southwest part of state, just north of Portland, OR) I will be happy to help. Also, I am skeptical, the striker broke by itself. I think there is something else amiss. This broken piece is a result, and not a cause. I would hate to have you fix this, only to duplicate the exact process because the cause wasn't discovered. At any rate, a few minutes with an auto body shop technician or an RV repair technician (some are mobile) will educate you on what tools are needed and they can give their two cents to boot. Good luck.
bill
oh-be sure to give the door some other kind of latching if you move the trailer-don't allow the door to spring open when towing-the bill will be considerably higher.
wmarsha is offline   Reply With Quote
Old 08-26-2010, 02:04 PM   #11
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Andy,
You must be busy today. You usually give the how to's on removal, replacement, parts required and how to do it. It's how I learn.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 08-26-2010, 04:11 PM   #12
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Chris said that if you pay his way from MN he'll come take care of it for you!
Actually, you probably need to replace the striker plate with the same one again - a household one will NOT work, without a major modification and is not worth the effort. Pop rivets are easy to do - I can do them all, and drill out and replace, (and get Vulkem under my nails, and cut holes in the side of the AS too!). You're best bet is to buy one from Out of Doors Mart, or Inland, or Vintage RV. Don't know why it locked on you, but probably was something going wrong inside it anyway. Older trailers get lots of little (or sometimes not so little) quirky problems as they age. Replace it correctly and you'll get 30 some more years out if it!
Kay
Old 08-26-2010, 05:14 PM   #13
MonaxLisa's Avatar
bill
That's so nice of you to offer to help! Unfortunately I'm up by Belfair which is about 3hrs away. The striker didnt break by itself, it was broken off because I was locked in and since I was shouting to not break the $500 door handle/lock the striker plate was what got the axe.
Does anyone have any tips on how to bungee (or something) the door closed? I cant figure out anything that I can attach anything to to keep it closed for sure.
Old 08-26-2010, 05:50 PM   #14
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
If you have an outside doorhandle, you need a doohicky
http://www.airforums.com/forums/f453...tml#post191050
Check out this thread for more ideas.
Stephanie
What is this thing? newroswell Brakes & Brake Controllers 3 03-30-2009 12:23 AM
What is this thing, anyway? cosmos Repairing/Replacing Floor &/or Frame 7 12-27-2007 05:13 PM
First thing to do? slimitch Cleaning, Stripping & Polishing 1 12-09-2007 08:44 AM
What's this thing? tmcdougald Lights - Interior & Exterior 6 07-22-2005 08:32 PM
