Old 08-26-2010, 07:17 PM   #15
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
doohickey or duct tape
no matter what, if ya gotta move it, make sure the door cannot open-even if it looks like a "redneck deadbolt!"
wmarsha is offline   Reply With Quote
Old 08-26-2010, 08:48 PM   #16
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Originally Posted by Goin camping View Post
Andy,
You must be busy today. You usually give the how to's on removal, replacement, parts required and how to do it. It's how I learn.
Andy was right on it (Post #4). I hear he sells the part also.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 08-26-2010, 11:27 PM   #17
MonaxLisa's Avatar
1975 31' Excella 500
undetermined , Washington
The link didnt work, can you try reposting? I tried using the search function but couldnt find it.
MonaxLisa is offline   Reply With Quote
Old 08-26-2010, 11:37 PM   #18
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I fixed the link, try it now.
Stephanie
Old 09-01-2010, 10:25 AM   #19
MonaxLisa's Avatar
Thanks for fixing that link! I really like the door stopper idea, simple! I glued the broken piece back onto the striker, I didnt want to shell out for a new one and have to break it again if I got stuck inside. So I'll make a stopper on the outside for when it's moving, since the super glue might loosen. Thank you!!
Old 09-01-2010, 10:45 AM   #20
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I bought a rivet gun on Amazon for less than $20. Rivets can be found in a hardware store. The drill bit for 1/8" rivets is a #30 drill bit, not a 1/8" bit. It is pretty easy if you have any experience with drills. The door may be out of adjustment and possibly from sagging or loose hinges. That's more likely than a problem with the striker plate.
Gene
Old 09-01-2010, 05:55 PM   #21
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Check to see if the inner door handle is tight on the shaft. There is a screw on the bottom side. Otherwise I would say that your lock mechanism is worn and will need some tweeking at the very least. If you are mechanically inclined, you could remove it to see what the problem is. I did mine and made the necessary repairs to get it to work better. Good Luck!
What is this thing? newroswell Brakes & Brake Controllers 3 03-30-2009 12:23 AM
What is this thing, anyway? cosmos Repairing/Replacing Floor &/or Frame 7 12-27-2007 05:13 PM
First thing to do? slimitch Cleaning, Stripping & Polishing 1 12-09-2007 08:44 AM
What's this thing? tmcdougald Lights - Interior & Exterior 6 07-22-2005 08:32 PM
