Old 09-15-2010, 08:31 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Replacing key cylinder for Bargman L-77
Just bought a new key cylinder for my Bargman L-77 from VTS. I have the lock apart now but can't figure out how to get the old cylinder out.
Can somebody give me a pointer or two?
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 09-15-2010, 08:54 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
It's been awhile but if memory serves me correctly you need to remove a pin that holds in the lock cylinder. Don't drop the pin. The lock cylinder should come out and then reverse what you did to put the new lock in. Hope this helps.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 09-15-2010, 09:03 PM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Hi Lee,
Thanks for responding. I don't see the pin you're talking about. I see a spring loaded wire that keeps the door handle under tension but don't see any pin. The top pic shows the cylinder in the center but there no retainer I can see. The bottom pic shows a small hole. I thought If I stuck a pin or small nail in this it would release the cylinder, but no joy.
ID:	110820   Click image for larger version
1958 Overlander
4CU 1st VP
Old 09-15-2010, 10:08 PM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I'm wondering if the "key" (no pun intended) to removing the old key cylinder is to turn the lock to retract the pin but I don't have keys to the old lock, that's why I bought this new one from VTS. Do I need to take this to a locksmith?
1958 Overlander
4CU 1st VP
Old 09-15-2010, 10:24 PM   #5
nmbosa's Avatar
Nowhere , Washington
Mike, I think you might be correct. If I remember correctly (I replaced mine about a year ago) I had to turn the key until the pin lined up and then I was able to pull the cylinder out.
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 09-15-2010, 10:51 PM   #6
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Mike ~
Read your PM. That small hole is how it works. I didn't have a key either but I got it to work. Just takes some finnagling to get it loose.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 09-16-2010, 04:42 AM   #7
richinny's Avatar
2011 34' Classic
look on the new cylinder for something like a pin or tab that is spring loaded.
Ricky
Old 09-16-2010, 06:15 AM   #8
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Does the old cylinder pull out from the back or front?
1958 Overlander
4CU 1st VP
Old 09-16-2010, 08:40 AM   #9
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
It should pull out the front. With the pin pushed in, you'll need to push it out from the back if you can get at it.
FF
Old 09-16-2010, 08:40 AM   #10
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
FF
Old 09-16-2010, 08:40 AM   #11
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
FF
Old 09-16-2010, 09:51 AM   #12
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Thanks Brad
Thanks Brad
Thanks Brad
Seriously, this change out is harder than I expected.
1958 Overlander
4CU 1st VP
Old 09-16-2010, 01:03 PM   #13
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Man, this thing is starting to tick me off. There is no give when I push the pin in that small hole. It's rock solid.
And the new cylinder doesn't shed any light on the matter either. The gold pin on the new cylinder lock doesn't move when I turn the key.
Geez!
1958 Overlander
4CU 1st VP
Old 09-18-2010, 05:59 PM   #14
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Okay, got this thing figured out and fixed today. The tip of an old key was broken off in the old key cylinder and I couldn't get it out to remove the cylinder, so I had to take it to a locksmith. He stated that you either have to have the key to remove the cylinder or you must pick the lock. After drilling out the lock to remove the broken off key, he was able to pop the cylinder right out.
So here's the bottom line for others who have to rekey this lock, you must turn the key in the old cylinder (or pick the lock) and push the little pin in at the same time to get the cylinder out. Oh yeah, the cylinder comes out the front not the back.
1958 Overlander
4CU 1st VP
Lock Cylinder niftypkg Doors & Locks 2 12-28-2008 11:13 AM
Master Cylinder Jim Casavant General Motorhome Topics 2 12-02-2007 04:21 PM
Master cylinder pjude Classic Motorhomes 2 07-23-2007 08:08 PM
Brake master cylinder install Robfike Mechanics Corner - Engines, Transmission & More... 1 01-08-2006 08:37 PM
Master Cylinder Replacement will Airstream Motorhome Forums 3 08-16-2003 06:35 PM
