Old 09-19-2010, 10:56 AM   #15
bevman's Avatar
1958 22' Flying Cloud
Saint Helena , California
just be careful with the new lock cylinder. I'm on my second new one in two years. The body is "pot metal" and will fracture if you force it. If you keep the locking mechanism inside the handle/lock body well lubricated then the tiny cylinder won't have to work too hard to slide the mechanism to lock/unlock positions. (The little cam on the back of the cylinder seems undersized for the amount of work we are asking it to do.)
-Michael
TAC CA-12
"All things in moderation, including moderation"
- Mark Twain
bevman is offline   Reply With Quote
Old 09-19-2010, 02:58 PM   #16
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Thanks, Michael, for the warning on these new cylinders. Funny you should mention the quality of the cylinders, the locksmith I took my Bargman to said that this cylinder wasn't a good quality unit and that you can buy one that is better. I should have asked him who makes the quality unit and where they can be found. He confirmed that this style of cylinder is called a Hurd Cylinder.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 09-19-2010, 03:17 PM   #17
bevman's Avatar
Might be a good idea to follow up with your locksmith to see if we can get a source for a better solution. I fear that I will need another somewhere down the road.
-Michael
TAC CA-12
- Mark Twain
Old 09-19-2010, 03:49 PM   #18
nmbosa's Avatar
Nowhere , Washington
Second that. I have not been too impressed with mine.
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 02-27-2012, 01:10 PM   #19
Vintage Trailer Supply
VintageRV's Avatar
1956 22' Caravanner
Montpelier , Vermont
L-77 Lock Cylinder Replacement
Hey folks. A couple thoughts on this old thread: 1) Yes, I agree the quality is not great on the cylinders available today . If a locksmith has a better source *please, please* share it with us all. 2) the way to remove the cylinder when you have a key is to insert the key and turn 1/8 turn or so and wiggle while depressing the release pin in that little hole in the chromed lock casting. It pulls out toward the key. 3) the way to remove the cylinder when you do NOT have a key is to either take to a locksmith or do it yourself by drilling out the cylinder from the key slot side. The old cylinders are not real hard so any good drill bit can do it. Drill out enough of it to hollow out as deep as where the release pin comes into the body of the cylinder. Then drive the release pin into the void you've created. Do not drill through the little release pin hole...not worth damaging that part of the lock casting . Really, it isn't hard to do yourself.
Steve Hingtgen
WBCCI #1573
VintageRV is offline   Reply With Quote
Lock Cylinder niftypkg Doors & Locks 2 12-28-2008 11:13 AM
Master Cylinder Jim Casavant General Motorhome Topics 2 12-02-2007 04:21 PM
Master cylinder pjude Classic Motorhomes 2 07-23-2007 08:08 PM
Brake master cylinder install Robfike Mechanics Corner - Engines, Transmission & More... 1 01-08-2006 08:37 PM
Master Cylinder Replacement will Airstream Motorhome Forums 3 08-16-2003 06:35 PM
