Old 11-14-2014, 11:13 AM   #1
ghatfield's Avatar
2006 19' Safari SE
Anacortes , Washington
Replacement for "Captain Hook" door handle
One of the irritating features of our 2006 19' Bambi is the lever type door handle to the head. It seems to have the uncanny knack of catching one of my belt loops ever time I pass it. I'm not the only one with this problem... there have been other threads on replacing this handle. For example:
http://www.airforums.com/forums/f453...h-32520-2.html
But here is a way to replace the handle in about 15 minutes at a cost of less than $10. I was able to find a knob set at Lowes that will fit the striker mechanism that is part of the stock door knob set (see photo). This allows one to keep the SS cover that is under the knob set. It happened to be the cheapest one that Lowes carries. Several styles are available. The new set is designed for a minimum door width of 1 3/8" and the AS door is 1" thick. So some surgery is needed. I used my Dremel to cut 1/4" off the central spline (but not the one going to the lock) and the two screw attachment points (see pic). This allows the new knob set to fit the door perfectly.
It is also good to bend the striker plate over a bit so it does not catch someone who is passing through the door.
George
Name:	airstream latch.jpg
ID:	226498   Click image for larger version
Name:	Lowes door knob.jpg
Name:	cuts to be made in knob mechanism.jpg
ID:	226500   Click image for larger version
Name:	installed door handle.jpg
ID:	226502   Click image for larger version
Name:	door catch.jpg
ghatfield is offline   Reply With Quote
Old 11-18-2014, 09:58 PM   #2
1977 23' Safari
1986 34' Limited
Idaho Falls , Idaho
Now that is clever! I don't have the problem (all of ours are vintage), but I sure admire your ingenuity!
Vivian
Richard and Vivian
Caliban The Wonder Dog: gone but not forgotten
Cerberus
Too many vintage A/Ss...
Landshark is offline   Reply With Quote
Old 11-18-2014, 09:59 PM   #3
1977 23' Safari
1986 34' Limited
Idaho Falls , Idaho
And the clarity of your instructions!
Vivian
Richard and Vivian
Cerberus
Old 11-22-2014, 11:00 AM   #4
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Happen to have the part# for the knob set you used?
Al - K4GLU is offline   Reply With Quote
Old 11-22-2014, 11:36 AM   #5
terryV's Avatar
2002 31' Classic
Monroe , Iowa
Those irritating little Bambis (or is it Bambies)
terryV is offline   Reply With Quote
Old 11-22-2014, 02:28 PM   #6
ghatfield's Avatar
2006 19' Safari SE
Lock set
Al... I think this is the one I used. No key, but it locks from the inside. Just need to turn the slot on the outside to open.
Shop Gatehouse Gallo Stainless Steel Tulip Turn-Lock Privacy Door Knob at Lowes.com
George
Old 07-25-2015, 02:14 PM   #7
nick_gee's Avatar
2011 28' International
Stillwater (last known) , United States
wow - glad I stumbled on this - one of my pet peeves fr sure. . .catching that belt loop - and your documentation is stellar - are you an engineer? cheers
nick_gee is offline   Reply With Quote
Old 07-25-2015, 02:30 PM   #8
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Yup, darn near ripped it off one day...LOL
OMG, and I thought I was the only one.....LOL
On my 2009 Int 27FB....handle caught me so many times I finally cut it off....or bent it so it no longer projected into the aisle.
Fortunately on my current AS they have corrected this. Will look for a photo which maybe shows the mod.
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 07-25-2015, 02:36 PM   #9
Msmoto's Avatar
2007 25' Safari
Images: 135
Final solution to the Captain hook
http://www.airforums.com/photos/show...i=24186&c=3389
Old 07-25-2015, 03:01 PM   #10
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My solution to the same problem was even simpler. I removed the door and all its associated fitting. Easy enough to close the accordion door for privacy when required.
MICHAEL
Old 07-25-2015, 05:09 PM   #11
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Many may not realize but the claw handle is actually handicap accessible, a knob is not friendly to a large number of folks. So if you are wondering why they used it, there is a reason.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 07-25-2015, 06:44 PM   #12
AWCHIEF's Avatar
Images: 33
I grew up in Germany. Claw type door handles were common. We used to talk about getting back to the land of the round door knob.
MICHAEL
Old 07-25-2015, 10:40 PM   #13
Nomadic , USA
Some cities have actually mandated it as building code. We where somewhere last year where that was the case. Vancouver is one such place.
Old 07-27-2015, 05:42 AM   #14
Msmoto's Avatar
2007 25' Safari
Images: 135
Door handle
It would seem the new recessed handle on my latest Serenity is also handicapped useful as one can simply slide it to open the door.
And, I think I investigated changing my claw to a recessed handle and it was not possible.
The curtain worked well with the foldette doors for extra security as noted.
door handle, door knob, door latch
Closet door hook replacement Andreasen Windows, Doors, Locks & Vents 4 09-29-2011 02:05 PM
Hook up OR Not Hook up while camping purman Boondocking 29 08-18-2009 06:42 PM
owner, operator, captain richard morg Member Introductions 4 04-28-2006 05:32 AM
Captain Morgan cptmorgan Member Introductions 4 04-10-2006 06:32 PM
