Old 02-01-2014, 10:59 PM   #1
1969 29' Ambassador
Portland , Oregon
Replacement for Bargman L-100
Hi, I'm looking for a replacement lock for my 69 Ambassador. I've taken the lock apart, cleaned and inspected. It's worn beyond being able to use one of the rebuild kits. The plates are cracked, threading is worn, and part of molding that accepts the screw is broken.
I've been looking around for a couple weeks now and can't find an affordable replacement for the Bargman L-100. I believe I have one of the models with the longer lock bolt.
I have her parked on the street so need to come up with a solution soon. Does anyone know of another brand/model of lock that might work as a replacement? Has anyone tried any of the TriMark models?
Thanks in advance!
O.Driftwood
o.driftwood is offline   Reply With Quote
Old 02-02-2014, 10:29 AM   #2
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
I sent you a private email. I can help you with a new in box Bargman L-100 or L-200 lock. I sent both a private and regular email to you.
Rick
montanablue is offline   Reply With Quote
Old 02-02-2014, 11:40 AM   #3
Thanks in advance!
O.Driftwood
The Trimark lock as a replacement works great.
But it must be modified with a longer striker bolt, a longer lock bolt, and shims.
A replacment kit is available, but it's cost is a function of all the changes and modifications to it.
No commercially availale lock, as an example, has the longer striker bolt, which it must have because of the thickness of the cast door frame.
Old 02-02-2014, 12:53 PM   #4
Baltimore , Maryland
L100 or L200 are not the correct lock for 1969
Old 02-02-2014, 07:47 PM   #5
1997 25' Safari
1973 25' Tradewind
I don't believe that is correct, because that is what is on my 69 globetrotter. the door has never been modified.
Old 02-02-2014, 08:45 PM   #6
Frank.
The lock for the 69odels was Chessler.
The L-100 or the L-200, is/was the exact replacement.
Old 02-06-2014, 03:12 PM   #7
1969 29' Ambassador
Portland , Oregon
Thanks Andy. I would love to upgrade the lock. For how much I'd have to pay for a reproduction or rebuilt Bargman I just figure get a better lock. The L-100s just don't seem like they are made very well.
Do you have any of the TriMark available with the replacement kits or do you know where I may be able to source them?
Thanks for all your help!
O.Driftwood
Old 02-06-2014, 03:22 PM   #8
O.Driftwood
Yes, we have that kit available.
Old 02-12-2014, 09:55 PM   #9
Stevelou
1984 27' Sovereign
1984 27' Airstream 270
Wandi , Western Australia
Andy we bought a replacement lock from you for our 1984 motorhome but when we got it the size was very different, we would have to cut the outside of the door one way and have a hole in the other side were the locks different for the trailers and the motorhome maybe? Steve (Australia)
stevelou is offline   Reply With Quote
Old 10-20-2016, 05:31 PM   #10
1959 22' Flying Cloud
Rockville , Maryland
Also looking for a bargman l100 or 200 replacement
Originally Posted by inland rv center, in View Post
yes, we have that kit available.
do you still have these available?
mallosrn is offline   Reply With Quote
Interior Dome Light Lens Replacement harleyag70 General Repair Forum 1 01-25-2014 03:02 AM
Replacement issues wander'n Refrigerators 0 10-11-2011 06:25 PM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
