Old 08-04-2007, 01:48 PM   #1
2007 19' Bambi
Bellevue , Washington
Replacement Door for 75th Bambi
Ok, long story short, I need a complete new door. I have been afraid to ask the body shop or Airstream if making a new one is possible. This is one with the round port hole window and only available on the 75 models they made. Model year 2006/2007. Also the screen door has that special "Jackson Center..." cut out. That may be able to be salvaged.
What are my chances of getting a new one to replace mine?
Asher
asherkobin is offline   Reply With Quote
Old 08-04-2007, 02:00 PM   #2
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Have you asked Airstream directly? It wouldn't hurt. If anyone would have an idea of availability I'm sure they would. I've also read from many others on the forum that they are extremely helpful and enthusiastic when it comes to repairs. Bummer on the need for a replacement though, but life happens.
Barry
safari57 is offline   Reply With Quote
Old 08-04-2007, 04:45 PM   #3
bobkelly's Avatar
2003 22' International CCD
Whittier, California , Depoe Bay, Oregon
Absolutely screw up your courage and call the factory. That is the absolute best place to get the quality replacement you need for this special trailer. The round window is an add on to the regular door that they have in abundance. The stainless steel screen guard was still available recently. I'd say your chances of scoring a new door are very good.
2003 22ft CCD Int'l
2005 GMC Yukon Denali
WBCCI #2960
bobkelly is offline   Reply With Quote
Old 08-04-2007, 05:04 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Good answers so far
New Airstream? I would only get it from the factory. And only allow an experienced and qualified dealer to install -- who knows if the door jamb side of the hinges are okay? Finding that good dealer service shop is your next question...
Sorry to hear about your loss.
5 meter Langford Nahanni
Old 08-04-2007, 06:59 PM   #5
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
I'd call Airstream of Spokane... they are the closest AS dealer that I'd trust.
Marc
Old 08-04-2007, 07:09 PM   #6
2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley , California
Ditto...
i want the same door in my '05.
when you find out, lets place an order.
kevin
Kevbo10 is offline   Reply With Quote
Old 08-04-2007, 07:43 PM   #7
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
kevin
Come to think of it, that would be a pretty cool mod! If you find out, post how much it will cost.
If you simply ask for the part from Jackson Center, they will refer you to a dealer because they don't sell direct, unless you have them install it at the service center.
Old 08-04-2007, 09:37 PM   #8
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Am I the only wondering what happened to the door?
Richard
Old 08-04-2007, 09:53 PM   #9
_
hi asher
the chances of getting a new one are quite good.
you can't order it from the factory but a dealer/service center can...
be advised a 'new door' isn't just a door...
it is the ENTIRE assembly (frame/hinges/door/window/latch/locks/screen)
these doors are built individually, with the frame, hinge and door fabricated together on a jig.
the screen assembly is sometimes reused but usually replaced too...
so the dealer will have to drill out the rivets and remove the current frame (whatever is left)
right down to the original cutout opening.
then the entire new unit is fitted, most likely with olympic rivets to replace the original bucked rivets.
unless the dealer/service center has buck rivet capacity...
i'm guessing about 3.5k$ for the hardware...
this process is somewhat like replacing a skin panel.
cheers
2air'
Old 08-04-2007, 10:52 PM   #10
denellen's Avatar
2007 25' International CCD
1964 19' Globetrotter
2012 Interstate Coach
vero beach , Florida
Question New Door?
Me Too. Que es?
Dennis & Ellen
07, 25' Ocean Breeze
64, 19' Globetrotter
Air #7609
denellen is offline   Reply With Quote
Old 08-04-2007, 10:57 PM   #11
_
Originally Posted by denellen
Me Too. Que es?
2 wild guesses
1. someone (the owner perhaps?) broke into the unit by prying the door open.
2. someone towed/moved the unit with the door ajar....byebye.
sure we wanna know what happened...
think of telling us as a learning experience!
cheers
2air'
Old 08-04-2007, 10:58 PM   #12
I See...
Originally Posted by 2airishuman
hi asher
// MASSIVE SNIP //
cheers
2air'
mr 2air,
so less than half the cost of say an average rolex for a cool door?
seems reasonable to me...
a vintage '05 CCD w/a porthole entrance door.
i'm in.
sign me up. i'll just raise rally fees.
k.
Old 08-05-2007, 06:58 AM   #13
lynn's Avatar
Sorry about your door. Are you sure your door cannot be repaired? A new door can be obtained from the factory ,the only unique part would be the round window which can be built.
Contact Kim Britt at Airstream,she is the parts manager and can help you as to availability.
lynn is offline   Reply With Quote
Old 08-07-2007, 07:03 PM   #14
2007 19' Bambi
Thanks for all your comments. The trailer is in the body shop (that was recommended by the dealer) being fixed right now. They only part they didn't have was the door. I need to call about that. Yes, it's very expensive, $3000. Total damage was $7000. I side swiped a concrete post that protects gas pumps. My fault for not judging the turn better. I was my first trip :'( so obviously I was going nuts. This was my trip to Casini Ranch where I met my first fellow Airstreamers and had a great time.
All the work is covered by insurance minus a $1000 deductable. In a way I'm happy I finally get something out of having something insured. State Farm was great. It only increased my yearly premium $50.
Asher
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 52 05-08-2018 01:31 PM
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Newbie AS Bambi Owner! KY Girl Our Community 12 10-27-2002 09:06 PM
61 Bambi Panel Replacement 61BambiCanada Ribs, Skins & Rivets 0 06-07-2002 09:41 AM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
