Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 12-16-2018, 01:15 PM   #1
my3sonsdad's Avatar
Vienna , VIRGINIA
Replace or repair
The prior owner of my 79 Argosy 30’ got locked inside which I’ve heard is a common experience. Unfortunately he had to “dig” his way out!
Looking at comments from a few aftermarket trailer locks, it appears that many they have a similar problem.
Are these lock assemblies repairable (service manual diagram below) or what have others used to replace them with that don’t suffer the same flaw?
2001 Ford Excursion 7.3L
my3sonsdad is offline   Reply With Quote
Old 12-16-2018, 03:30 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The tongue is still attached to the assemble, mine broke off ad had to be welded back on. Looking at the drawing there are only a few parts that would cause it to fail from the inside. Handle #2, cam #5 and the bolt plate #6. If the handle can turn the cam and the cam is contacting the bolt plate it should work the lock. The only other problem would be if the bolt plate is not retracted enough to clear the strike plate on the door frame. That may be a door hinge adjustment to correct that problem
I would remove the lock assembly and determine what has failed. Is a part just worn to the point of failure or has something broken. That analysis will give you the information to make a decision. I would look to repair the lock as fitting a replacement may require cutting the outer skin. As for the inner skin you can make a patch to cover the hole and finish off the door.
2004 Excursion 4x4
To Replace or Not Replace ( dome and fan ) estock Roof Vents, Skylights & Fans 2 05-20-2018 02:42 AM
To Replace or Not to Replace that is the Question Redleger Water Heaters, Filters & Pumps 3 10-15-2016 07:38 PM
To Replace or Not to Replace 65air Towing, Tow Vehicles & Hitches 3 03-29-2013 12:58 PM
2 replace decal or not to replace? nustreamer Clearcoat, Exterior Paint & Trim 1 07-15-2011 10:28 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
