Old 09-22-2010, 10:21 AM   #1
1975 31' Sovereign
Waterloo , Iowa
removing door with hinges
how are the hinges with door taken off. Do the screws attaching the hinge have a fixed nut on the inside, or are they held on by a removable nut, or are they screwed directly into the frame?
robertel is offline   Reply With Quote
Old 09-22-2010, 01:17 PM   #2
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
You may want to search / read through the forum articles
about this for a while.
kennethowens is offline   Reply With Quote
Old 09-22-2010, 02:07 PM   #3
1975 31' Sovereign
Waterloo , Iowa
I have read through the forums for anything relevant but can find nothing about removing the door with hinges on. I read a post about how someone removed the hinges on the door side and replaced the inner skin. Then he had to cut hole in the skin to access the hinge bolts. I'd just as soon take off the door with hinges .I just want to know what to expect. It would be a real drag if there were nuts and they either fell off inside the shell or wouldn't tighten up again.
Old 09-22-2010, 02:12 PM   #4
davenpow's Avatar
1975 31' Sovereign
Canby , Oregon
just finished installing a new door and frame in my 75 31 footer.
nut and bolt, easily drooped. You need access be hind the inner skin.
Ted
davenpow is offline   Reply With Quote
Old 09-22-2010, 02:17 PM   #5
1975 Argosy 24
Malakoff , Texas
I also remember reading that article. You will have to open and access
the inside to get to the back of the bolts. Unless I am mistaken.
Old 09-22-2010, 03:18 PM   #6
1975 31' Sovereign
Waterloo , Iowa
are you talking about the nuts on the inside of the door? I already know that. I mean the bolts holding the hinge to the body of the trailer. Are there nuts on them that will fall so I will have to remove the inside skin of the trailer itself, not the door.
Old 09-23-2010, 06:32 AM   #7
1975 Argosy 24
Malakoff , Texas
http://www.airforums.com/forums/f453...ose-63649.html
Old 09-23-2010, 07:26 AM   #8
davenpow's Avatar
1975 31' Sovereign
Canby , Oregon
I was talking about the hinge attaching to the frame.
Imagine looking down the length of the door toward the
floor with your head half in half out the trailer. The shape of the frame
is like the capital F. The door hinge and exterior skin are attached
to the top most horizontal leg of the F, the interior skin is attached
to the lower horizontal leg. The nut is in the space between. It can
and often did drop during the installation of the new door.
it is a Removable nut, no washer even. I did add a good lock washer when
installing.
Ted
Old 09-23-2010, 07:42 AM   #9
1975 Argosy 24
Malakoff , Texas
Ted,
Your answer seems to answer the original question.
Unless I am misunderstanding.
Where can I get cabinet/door hinges? Hummer Cabinets, Counter Tops & Furnishings 18 10-07-2014 08:36 AM
Plexiglas Door Hinges jglabrown Cabinets, Counter Tops & Furnishings 3 08-10-2009 06:45 PM
Main Door Hinges - 1964 jomama 1960 - 1964 Globetrotter 9 04-20-2008 01:24 PM
Door hinges & new screen door? JKWoodrow Doors & Locks 5 11-17-2006 09:39 AM
Door Hinges Ed Keyes Doors & Locks 4 09-06-2006 03:48 PM
