Old 11-22-2007, 08:48 PM   #1
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
Removing an Airstream Screen Door.
I want to permanently remove the screen door from my 1976 Argosy.
How do I do this?
I canít readily see how the main door hinge-pin comes apart.
The rivets could be drilled out of the screen door hinge but I would like to remove the entire screen door, including the hinge supports.
Information much appreciated.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 11-22-2007, 08:58 PM   #2
elbundi's Avatar
2005 25' International CCD
Leesburg , Georgia
i too would like to remove my screen door, only to fix the crack that has developed around the middle hinge. apparantly the method is to drill a small hole on the underside and then use a center punch to push out the retaining pin.
im sure (hopefully) some other forum member will chime in with more information about this process. Can you use the same pin, what size bit to use to drill the hole etc?
elbundi is offline   Reply With Quote
Old 11-22-2007, 09:49 PM   #3
How do I do this?
I can’t readily see how the main door hinge-pin comes apart.
Sergei
I would suggest that you leave the screen door hinge in place.
After removing the screen door, you can fasten it's hinge to the back side of the main door.
Taking the hinge apart is not a good idea, as once you remove the pin, it will always want to come out by itself.
Old 11-29-2007, 05:45 PM   #4
1976 Argosy 24
Thanks Andy.
I was hoping the screen hinges could be neatly removed but I defer to your long experience.
Maybe I can cut the screen hinges close to the main hinge and hide the cut-off portion on the backside of the door, in the jamb in other words.
Can you please PM me with your best price on a set of window rock guards for the 1976 Argosy, including shipping to Ontario (Canada, not California.)
Sergei
Old 11-29-2007, 07:15 PM   #5
Excella CM's Avatar
1978 31' Excella 500
Venice , California
On the other hand, if you leave the hinges intact, the next owner might be much obliged.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 12-01-2007, 08:07 PM   #6
1976 Argosy 24
Smile
Excella:
There was no window in the original Argosy door so we put one in.
See post #280 here:
http://www.airforums.com/forums/f227...-18448-20.html
I canít have both a fully operating screened window (which I prefer) and the screen door.
Maybe a future owner will appreciate that change too.
Sergei
Old 12-14-2007, 04:39 PM   #7
1976 Argosy 24
Changed my mind
Iím keeping the screen door after all. Phil, who helps me a lot around the project, rhapsodized about looking out onto a field of Tiger Lilies while parked on the Saskatchewan prairies. Or maybe it was just a field of flowers somewhere. Anyway, I was convinced.
Iím going to drill out the rivets, however, and have the door painted to match the trailer, then re-screen it.
Sergei
Fixing screen door screen wacnstac Windows & Screens 8 04-09-2007 10:35 PM
Screen Door Guard Airstream Company Killo1 Off Topic Forum 13 03-29-2007 11:42 AM
Door hinges & new screen door? JKWoodrow Doors & Locks 5 11-17-2006 09:39 AM
Weather seal for '57 door and screen door cdmagda Doors & Locks 0 09-01-2005 09:40 AM
