Old 07-19-2012, 02:21 PM   #1
1972 23' Safari
Neptune beach , Florida
Removal and reinstall black dlide lach that holds entry door open.
Have a 71 trade wind, I broke off door lacch that keeps door open. How to r&r black latch w spring inside.
Rmoran113 is offline   Reply With Quote
Old 07-19-2012, 02:30 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Drill out the pop rivets that hold it on with a 1/8" drill. Replace the broken part(s). Reattach with new pop rivets.
Simple.
Vaughan
Old 07-19-2012, 07:01 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Which part did you break - the black slide itself or the small lip black lip that it catches on. If you can avoid removing the spring loaded latch it's a good thing.
If you have to remove it - slide it all the way back to the open position. Slide a thin blade (I used a 1/2 wide flexible putty knife) between the top and bottom portions. Pry up and at an angle. Watch the spring inside go flying when the top pops off. No guarantees it won't break if it's old and dried out.
