Old 03-18-2005, 05:37 PM   #1
58BUBBLE's Avatar
Refer Handle Lock Cylinder, Same As Ford
On vintageairstream.com they say that the 50's refer. type door handle lock cylinder is the same as the ones used in 50's ford ignitions called a "Hurd cylinder". I need one to make my door handle functional again. Does anyone out there know where you can get one of these "hurd cylinders"? Are they still available or do I have to hunt for one ouit of an old ford? TIA
58BUBBLE is offline   Reply With Quote
Old 03-18-2005, 05:45 PM   #2
AirConditioner's Avatar
Hurd available locally
Call Rick at Key Way Locksmith
(801) 521-0869
854 S Redwood Rd
Salt Lake City, UT 84104
They should have it in stock, or can order it. Around $12 -25 with 2 keys is the going rate
AirConditioner is offline   Reply With Quote
Old 03-18-2005, 05:50 PM   #3
Images: 59
Here's another possible source:http://www.airforums.com/forum...6&postcount=15
Old 03-18-2005, 06:13 PM   #4
aztlanco's Avatar
El Paso , Texas
Send a message via AIM to aztlanco
If you want to search for old Ford parts, you might try "Bob Drake" at
www.bobdrake.com
They specialise in old Ford Parts.
Ernie
'58 Traveler, 18ft. 1950 Ford F-1 tow vehicle
aztlanco is offline   Reply With Quote
Old 03-18-2005, 09:21 PM   #5
58BUBBLE's Avatar
WOW, you guys are amazing. Don, both of those look like they could be the one. Airconditioner, My office is about 5 miles up the road from that locksmith and I didn't even know they existed. Isn't it great that I can submit a question and someone across the U.S. gives me a possible solution only 5 minutes away. I will be there 1st thing Monday morning. I love these forums!
310 door lock parts joepospisil General Motorhome Topics 8 10-02-2012 11:14 AM
That @#*# Lock niftypkg Doors & Locks 16 11-20-2005 02:28 PM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
Door Lock replacement? 3Ms75Argosy Doors & Locks 2 08-15-2002 11:12 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
