Old 08-08-2006, 06:04 PM   #1
kamo's Avatar
burbank , California
Rear service entrance door locked
The rear service entrance door (?) (then one that has the shutter like pattern) is locked and I don't have the key for it. This is my recently purchased 62 Bambi.
How can I get in there with as little destruction as possible?
Kamo
kamo is offline   Reply With Quote
Old 08-08-2006, 06:26 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Locked Door
Those locks are relatively eady to pick with a cheap lock pick kit.
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 08-08-2006, 06:37 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
If you don't have the tools or training, take it to a locksmith. They will open the door in about one second.
Bill
Just my personal opinion
Old 08-09-2006, 02:13 PM   #4
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Or do what I did. When I realized that I hadn't been given a key to the battery doors, I took it to the Airstream dealer in Toledo. The mechanic walked out with a big key ring, sat down, and started trying them one-by-one. He found a match within a couple of minutes.
And if you can get to the back of the compartment door, you can take the nut and lever off to get the door open. Then take the big nut off, and take your lock assembly to the hardware store to see if you can match up the cylinder. It shouldn't even be very expensive. (Don't tell them it's for an Airstream.)
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 08-09-2006, 05:06 PM   #5
kamo's Avatar
Thanks for the suggestions.
I might actually try to open the lock myself. Found this video on google:
http://video.google.com/videosearch?q=lock+pick+making
Old 08-09-2006, 05:23 PM   #6
RobertC's Avatar
1970 21' Globetrotter
Pickens , South Carolina
I didn't get any keys with my Globetrotter either. I have a huge collection of keys and after about 5 mins I found one that worked! I had to find a different one to lock the main door though, but once I lock it I have to take the lock out of the door to unlock it. Also I have no way to lock the door from the inside, thinking I need a new lock assembly but so far I havn't found anything online.
Skip Callaham
RobertC is offline   Reply With Quote
Old 08-13-2006, 11:35 PM   #7
kamo's Avatar
Well, door is open, but I couldn't pick the lock.
I took out the drawer between the stove and the fridge and I could reach in there with a screwdriver and took out the screw holding the the latch on the end of the lock. Now I have to find new locks.
Old 08-14-2006, 12:09 AM   #8
1986 32' Excella
vledder , drenthe
Images: 8
Just try some key's from other airstreams
A frend om my in belgium also didn't had the keay for his compartment doors.
I trye'd my key's and they did fit.
Have the idea that airstream do's juse a lot of the same key's
remcolent is offline   Reply With Quote
Leak at rear bedroom wall Kirby Stone Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 02-12-2010 11:41 AM
Vote on lost key return service 66TradeWind Community Polls 12 05-01-2009 10:28 AM
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 08:28 PM
Leak in the rear JodynJeep Sinks, Showers & Toilets 10 09-08-2006 09:40 AM
rear air suspensiom problems wb13798 Airstream Motorhome Forums 19 03-03-2003 07:12 AM
