Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 10-17-2009, 11:58 AM   #1
Profile:  1984 31' Excella
Bel Air , Maryland
Pushing in door to unlatch problem
I bought a used trailer and the PO said that someone had broken into the trailer and bent the door. To unlatch the door you have to push/pull the door shut to release the tension on the latch and then unlatch the door. I need to get this fixed so my young kids can open the door if needed. Any advise on repair? - Thanks
Two Adults, Four Kids, and a Dog camping in an Airstream. We must be crazy!
Silverscream is offline   Reply With Quote
Old 10-17-2009, 12:27 PM   #2
Profile:  1986 31' Sovereign
Miami , Florida
I have an 86 Sovereign and had the same problem -- it wasn't the door but the gasket. It was so old it wasn't resilient, no "give" and held the door hard against the latch plate.
If the door is indeed bent, I personally would take it to a reputable AS dealer. Aluminum, unlike steel, has no "memory" so reshaping it is a problem.
Good luck,
mike
Old 10-17-2009, 01:40 PM   #3
Commercial Vendor
Profile:  Corona , California
The lock striker bolt could also be "grooved".
If so, you will need to replace the lock, since the company that made your lock, is out of business. No parts available.
You should also check the "striker pocket" for unusual wear.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-17-2009, 05:53 PM   #4
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
If you can do some wood working consider cutting a piece of 2x6 with a bow slightly less the the curve of the door frame. The reason for cutting the curve slightly less that the curve of the door frams is you have to OVER BEND metal to reach the desired bend. Then with this wooden form place it against the outside edge of the door and with clamps pull the door back into shape. If you are only moving the curvature of the door a bit this will work. Do this a little at a time checking as you go to be sure you don't bend it TOO much.
Did this in the field last year for a door that was out about 1 1/2.
As far as the lock is concerned I just had to rebuild mine because the latch broke off the plate that pulls it open. Also had to make a new spring for the dead bolt lock out of a hack saw blade.
You put your mind to it you can fix anything.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
HowieE is online now   Reply With Quote
Old 10-18-2009, 08:52 PM   #5
Bel Air , Maryland
Grooved latch/deadbolt
I looked at the door latch and it is grooved on the street side. The dead bolt is grooved on the interior side. So I would guess I need to replace both. Any ideas on where I can get the replacement lock and deadbolt? The lock/latch looks like it gets removed by taking out screws and pulling towards the outside. I don't know about the deadbolt. Any ideas?
thanks, much appreciated!
Old 10-18-2009, 10:55 PM   #6
HowieE's Avatar
Images: 11
If you have a pull handle on the outside of your trailer you will have to remove that handle to get to the dead bolt. The picture shows 2 access holes cut to remove the handle. The dead bolt is bolted on and accessed through the upper hole. You will find the lock potted in caulking that can be dug off to get to the bolts. Make the access holes small enough that you can cover them with white blank electrical plates. You can just turn the dead bolt over and use the other face
The door lock is no longer available. The replacement is a kludge looking thing that is held in place by over sized plates on both sides. Short of the spring having broken I can't think of any other part that can't be fixed.
Pushing Daisies PeeWee Airstream "In the News" 2 10-01-2008 11:02 AM
Pushing Daisies Airstream Forrest Airstream "In the News" 3 08-29-2008 01:40 PM
Are we pushing the limit? flitzwhopper Tires 4 06-24-2006 02:51 AM
Shower Door Problem dmac 2003 Safari 3 10-20-2005 10:34 PM
1976 door problem Rennegarbe1 Doors & Locks 3 01-15-2003 03:49 PM
