Old 09-06-2015, 06:54 AM   #15
2013 25' Flying Cloud
Vian , Oklahoma
I checked with 6 places in Colorado, Arkansas, and Oklahoma and none of them would do the copy job. Even after I had the blanks from Airstream, the Walmarts said their equipment would not accept them. I tried a Home Depot, Lowe's, local locksmiths, and RV services near by. My problem was solved with the local Ace Hardware that cut them with a their "old fashioned" method from those blanks. I guess there have to be a few difficult situations now and then to keep us on our toes. Time was a factor initially, but that was soon abandoned. Thanks to all that commented, I just thought the info might help others.
Okie 1 is offline   Reply With Quote
Old 09-06-2015, 10:52 AM   #16
2014 22' FB Sport
Mpls , Minnesota
You guys rock! Sure appreciate all the input, and I think we have it under control. The graphite powder helped, as does pushing back gently on the key. I can pretty much get it on the first try now. Also learned that my keys are "newly cut" with sharp edges. They should get more forgiving with some use as the edges smooth down a bit. Thanks again, Jeff
MN Jeff is offline   Reply With Quote
Old 09-06-2015, 01:08 PM   #17
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Problems unlocking door with key
Originally Posted by Beach Bum View Post
We had a similar problem with our door lock ( not lock not the deadbolt.) We were constantly having to do the door lock jiggle to lock and unlock. We had it on our warranty list and the tech showed us the trick. He told us insert key and pull toward the back of the trailer then turn key. that will engage the key in the lock. Key and lock work first time everytime now. No repeat problem unless we forget the process
Benn
Wow! That really works! Thanks so much for passing on the tip.
Same from me. Jim
Jim Flower is offline   Reply With Quote
Problems Problems Problems pjude General Motorhome Topics 6 09-03-2007 07:25 AM
Missing Key for Potable Water Lock Door Streamer1 Doors & Locks 16 03-25-2007 08:00 PM
Key for water door Orland Dewey General Motorhome Topics 19 09-06-2005 06:12 PM
key for my water compartment door! pamelake 1970-79 Tradewind 14 07-27-2005 11:47 AM
door key tomb Doors & Locks 8 07-17-2002 11:16 AM
