Old 06-09-2010, 08:37 AM   #1
1974 29' Ambassador
Regina , Saskatchewan
problem entering a locked trailer
I went to my 1974 land yacht, which was in locked storage, only to find someone has tried to force the lock and as a result my key will not open the door.
I'm thinking of trying to shim the door, to spread the door frame enough so I can get the door open without unlocking it. What other methods have been successful for other people. Has anyone had experience in forcing the lock tumbler with a large screwdriver? Any advice before the weekend would be greatly appreciated. Is there a better method for entering a locked trailer?
Witherspoon is offline   Reply With Quote
Old 06-09-2010, 09:16 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I would not try and pry on the door frame. First it is cast and may well break, two, the way the interior skins are riveted to the frame I think you would cause major damage.
There are ways to get into Airstreams, most folks won't post them for obvious reasons. Might give Andy and Inland RV a call he has lots of ideas on problems like this.
Old 06-09-2010, 09:19 AM   #3
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
68 TWind is right - if you mess with the door frame, be prepared to live with the distortion forever. Andy has helped several others and am sure he will help you.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 06-09-2010, 11:47 AM   #4
tinhutjohn
tinhutjohn's Avatar
1974 29' Ambassador
London , Ontario
Images: 8
I had my lock broken by a theft attempt this winter. CanAM RV, my local Airstream dealer had to come out and drill a hole in the lock face plate and manually move the lock bolt over. They have diagram that shows precisely where to drill and how big of a bit to use. They had replacement parts (used) that they used to restore the lock with the same key.
If your dealer can't do the same thing, get in touch with CanAm at Can-Am RV > Home and I'm sure they can help you out or even give you instructions by phone.
Sarge
PS This might be covered by your RV insurance. Probably good to find out how much it will cost and decide if you want to make a claim. (attempted theft)
74 Airstream Ambassador International
94 Burb Ontario plate "TIN HUT"
02 Jetta TDI
Logan the Large hairy Golden Retriever
It's a monocoque thing
You wouldn't understand
tinhutjohn is offline   Reply With Quote
Old 06-09-2010, 02:07 PM   #5
2005 19' Safari
GLENDALE , AZ
Experienced locksmiths are familiar with RV locks. I'd call around to find one that has worked on Airstreams. They can usually repair or replace old locks that are out of production. (Some are even specialize in antique or unique locks.)
Old 06-09-2010, 04:30 PM   #6
hamiltonmj's Avatar
1965 17' Caravel
2013 Interstate Coach
Opelika , Alabama
I took a slim jim type tool on the emergency escape window and pushed the cams down that are holding the window tight. Then crawled through the window...had the help of the Stone Mountain Ga police...worked for me.
Mike Hamilton
WBCCI # 2766
2013 Airstream Interstate (Darth Vader)
1965 17' Caravel (R2D2)
hamiltonmj is offline   Reply With Quote
Old 06-09-2010, 05:45 PM   #7
1974 29' Ambassador
Thanks for all of the advice
I have talked to Can Am however I am in Saskatchewan which would likely be a 3 Day Drive. to their center. I will give Andy a call tomorrow.
Fortunately I don't have to use the trailer right away, and I guess my worst-case scenario is to break the small window beside the door. I will see if I can get in the back window utilizing the Slim Jim approach. Will let you know how I make out.
One of the reasons we bought an Airstream is because of the quality of the people we have met who are streamers, and your quick response reaffirmed this. Ron
Old 06-10-2010, 10:18 AM   #8
Ready-to-Travel
pmclemore's Avatar
We feel everyone's Airstream pain. Good luck.
Pat
AIR 3987
TAC VA-2
WBCCI 4596
Keys locked in trailer JerryLC Windows, Doors, Locks & Vents 21 05-21-2017 07:21 AM
Dog locked inside trailer with the keys! Kristi Foster The Pet Forum 62 10-29-2013 08:32 PM
Tips/Info for Entering Canada w/an Airstream mjaw On The Road... 18 08-28-2007 11:26 AM
Entering the Generator World... cynthia Generators & Solar Power 6 05-06-2005 11:11 PM
Breaking & Entering Navigator Doors & Locks 4 02-28-2004 07:34 AM
