Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 04-13-2009, 07:15 PM   #1
Profile:  2008 19' Bambi
Miami , Florida
Outside Door No Longer Closing Correctly
We have a 2008 19' Bambi SE that we notice the door is no longer closing correctly. Recently we notice we need to push against the door then pull to open it. There is no damage or dent. We're trying to see what can be done before taking it to the dealer. Can it be re-aligned? Could the screen door be causing the issue? Any ideas or assistance would be much appreciated.
MamaTRC is offline   Reply With Quote
Old 04-13-2009, 07:17 PM   #2
Profile:  1974 31' Sovereign
beautiful downtown Aurora , Ontario
Airstream Registry
Send a message via ICQ to Aage
Maybe the supports are set wrong, racking the trailer a bit? What's different about things since you noticed the door won't open?
i.e. what have you changed in terms of how it sits?
It's a combination of Alzheimers and Deja Vu - I keep thinking I forgot this before.
Aage is online now   Reply With Quote
Old 04-13-2009, 07:42 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Try this - 2005 25'SS Door sticking
Make sure your stabilizers aren't jacked up to level your frame or support it beyond the parking level which you set up with leveling blocks or boards.
BobStream
...You really don't know someone 'til you've had recess with them. ...Alex Ziton, age 8
Old 04-13-2009, 08:07 PM   #4
2008 Safari 27 FB SE
FordTruck's Avatar
Profile:  2008 27' Safari FB SE
Lynchburg , Virginia
What CanoeStream said.
FordTruck
2005 F-150 5.4L Supercab 4X4 (Betsy 3)
2008 Safari 27FB SE (Arvin as in RV'ing)
2006 Harley Davidson Electra Glide Classic (SOLD)
Fair is where they put ribbons on pigs.
FordTruck is offline   Reply With Quote
Old 04-13-2009, 10:31 PM   #5
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Airstream Registry
Greetings from the Florida Panhandle.
First check and see if the door is behaving the same if the the stabilizers are up or down. If it acts up with the stabilizers up, try minor adjustment on the Jamb pin.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
moosetags is online now   Reply With Quote
Old 04-15-2009, 02:41 PM   #6
Miami , Florida
It's the same if the stabilizers are up or down or even hooked up to the Expedition. I will have Hubby check the Jamb pin. This is a tad outside my expertise, but he should be able to handle.. Do you have any details on the Jamb??
Thanks to all who have so gracefully been responding to me!! I love being part of the Airstream Family!!
Old 04-15-2009, 02:57 PM   #7
RangerJay's Avatar
Profile:  2002 19' Bambi
Northwestern Ontario , Just above the big green spot
In addition to what has already been said lubricate the locking mechanism and latch.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2003 (The Buggy)
RangerJay is offline   Reply With Quote
Old 04-15-2009, 03:06 PM   #8
ESCAPE POD's Avatar
Profile:  2007 19' Safari SE
Seal Beach , California
Door closing
I've noticed the same problem with our '07 Bambi SE, and it seems to be related to the screen door "dragging", or catching on the abrasive door strip at the bottom of the doorway. You can tell if this is happening by separating the screen door from the main door, and closing it to see if it binds up on the bottom of the screen door. I haven't taken it in yet, but I'm wondering if a few minutes with an angle grinder on the bottom edge of the screen door might help.
"I saw in their eyes something I was to see in every part of the nation--a burning desire to go, to move, to get underway anyplace, away from any Here...free and unanchored."
-John Steinbeck
Jerry & Susan
2007 19' Bambi SE
2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Brakes working correctly? Dbraw Electrical - Systems, Generators, Batteries & Solar 8 02-27-2007 07:16 AM
Door not closing with stabilizer in place silverhawk25 Doors & Locks 10 02-01-2007 07:31 PM
Done Lurking (2nd try to post it correctly) c.j.lewis Member Introductions 3 03-04-2006 08:03 PM
Did I hear that correctly? SafeHarbor Off Topic Forum 10 11-26-2005 08:48 AM
Hard closing door on 1968 rluhr 1966-68 Caravel 26 04-02-2004 05:17 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
