Old 09-08-2018, 05:27 PM   #1
1977 27' Overlander
Portland , Oregon
Options for sprung door repair
Hey guys. Recently acquired a 1976 overlander. The door wasn’t sealing at the top of bottom so I took it apart to check it out. It appears to have been modded in a dumb way, causing a break at the door knob cylinder area.
What are my options to repair and straighten? Would you just re-rivet the plate where the damage is at after bending it in shape, or will welding be needed?
ID:	321884   Click image for larger version
licoricewhip is offline   Reply With Quote
Old 09-08-2018, 10:15 PM   #2
1977 27' Overlander
Portland , Oregon
Also, if anyone knows where to get a screen door replacement I’d be curious to know. The one on this airstream is trashed, I think beyond saving.
Old 09-09-2018, 08:35 PM   #3
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
I would install a sister on the inside.
You can make a cardboard template of the trailer curve and ensure the door follows the curve as you attach the skin.
sgschwend is offline   Reply With Quote
AC replacement-options, options... Belegedhel Furnaces, Heaters, Fireplaces & Air Conditioning 5 09-12-2018 09:56 AM
Front coil spring to air spring conversion. tedly797 Classic Motorhomes 1 05-24-2016 10:32 PM
Hensley Spring Plunger, Grease fitting spring bar retainer dznf0g Hitches, Couplers & Balls 2 08-29-2012 08:43 PM
Air Spring Options for Softly Sprung Tow Vehicle? overlander64 Tow Vehicles 15 11-29-2003 09:49 PM
How do I diagnose the soft spot, and what are the repair options? Narnian Repairing/Replacing Floor &/or Frame 12 09-01-2003 03:41 PM
