Old 05-04-2010, 03:41 PM   #1
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
Now, i'm over it....
My door blew open on the highway and cracked the frame at the lock. I had the door welded. This weekend I riveted the interior/exterior skins on and rehung the door. The door seems to be racked at the top. This year model has a cast aluminum frame. Ive have tried to find a welder to help, so far no go... they seem to be an elusive bunch. The guy that welded it originally is in ft.worth...too far to tow an unregister AS without a door.
Plan B find a door frame replacement for a 1970 27' International.
Which year models are interchangeable? Any sources??
Thanks, Cynthia
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline   Reply With Quote
Old 05-04-2010, 03:50 PM   #2
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
I saw one that is from a 68 Tradewind on the classifieds. Will it fit my 1970?
Old 05-04-2010, 03:54 PM   #3
JimGolden's Avatar
1977 31' Excella 500
Cynthia,
It's rather difficult to weld cast iron. Cast aluminum you almost never weld. I suspect that is why you're having a tough time finding someone to do it.
If anyone will do it at all, I'd recommend the TIG process. That MIGHT do it. But, to be honest, I've never heard of anyone welding cast aluminum.
Well, I say that, and I just lied to you: My grandpa had a guy try to weld a cast aluminum motor mount for him for a Saturn 4-door Sedan (an L300) that was in a wreck. The guy who welded it was a certified master welder, and he used the TIG process. He said he didn't trust it to hold. I bought the car...the weld failed. I spent the $60 and bought a new motor mount for it.
Bottom line: It's near impossible to weld cast aluminum.
Sorry to be a rain cloud...but good luck with your project.
- Jim
JimGolden is offline   Reply With Quote
Old 05-04-2010, 04:15 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
1969-1972, all models except Caravel (that's the narrower body).
Old 05-04-2010, 07:29 PM   #5
rideair's Avatar
Here you go.
http://www.hobartwelders.com/weldtal...ad.php?t=27635
Website for Welders,
Did a search for "welding cast aluminum" Got to love the web.
Paul Waddell
rideair is offline   Reply With Quote
Old 05-04-2010, 09:38 PM   #6
1980 31' Excella II
Drummond Island , Michigan
Had my door blow open twice now once because the lock failed and it blew open on the highway and once when we inadvertantly did not latch the door completely closed and a strong gust of Texas wind caught it and blew it open when we were parked. I replaced the door lock and replaced the door hold back that was also broken. The door is racked or bent at the top also. In reading the threads on the forum about A/S doors blowing open the bend out of shape is common. My frame is not cracked but the door will not bend back into shape. I think I discovered the reason why. After I repaired the door I also replaced the rivets that had popped that held the inner skin to the frame and added a few more new rivets. The sandwich of the inner and outer skins rivited to the frame is what makes the door stiff. I am in effect stopping the door from being bent into the correct shape by reriviting the inside skin. My plan is to remove the rivets from the inner door panel, make a jig by tracing the pattern of the door opening onto a 2X6 or 2X8. Cutting the wood along the pattern to make the jig and then clamping the door to this wooden pattern that mimics the arc of the door frame and then reriveting the inner panel to the door frame. I don't think the frame itself is the strength of the door. It is a hollow core door with two aluminum sheets attached to the frame. The frame forms the overall shape and provides a place to mount the latch and hinges but the attachment with rivets of the two skins to the frame makes the door very light weight and very strong.
Ahzmyrah is offline   Reply With Quote
Old 05-05-2010, 05:00 AM   #7
Kevin245's Avatar
Zepp did something along the same line though the vintage differs. See post #46 of http://www.airforums.com/forums/f381...?highlight=cry
Eleanor Roosevelt
Old 05-05-2010, 06:00 AM   #8
1977 Argosy 24
Milltown , Wisconsin
I think you would have to bend the top of the frame in more then is necessary, before you re rivet it because of spring back. Most times with any metal, you need to bend it more then what you want the final shape to be, as it always springs back somewhat to the shape it was before it was bent.
ventport is offline   Reply With Quote
Old 05-05-2010, 09:00 AM   #9
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Thanks Terry,
SADLY, Guess that Im a year too early for this one... ,
Cynthia
Old 05-05-2010, 09:02 AM   #10
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Wonder if I heat it up with mapp gas...would that help to reshape ?? Grabbing at straws here...
Old 05-05-2010, 09:10 AM   #11
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Kevin,
Zep is the Tin King, I think. What do you think he does in his "spare" time?? Ill take a look at his thread.
Thanks for the info. Cynthia
Old 05-05-2010, 10:02 AM   #12
Kevin245's Avatar
Kevin,
Rumor has it he pulled a gig with Garland back in the late 30's then quickly realized his future was in aluminum instead of tin.
Eleanor Roosevelt
Old 05-05-2010, 10:22 AM   #13
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Oh, I see...He has a thing for pigtails and alumninum
Old 05-05-2010, 10:48 AM   #14
1980 31' Excella II
I guess what I was trying to say is that the frame does not make up the major structural integrity of the door. If you can get the frame and outer skin back into the correct shape to fit the door opening and then rivet the inner skin in place it will hold that shape because of the "shear" strength of the rivets holding the skin to the frame all around the perimeter of the door. You could also reinforce the frame by fabricating a "mending" plate from aluminum that overlaps the crack by several inches and then attach it to the inside of the frame behind the inner skin. I would bond it to the frame with epoxy and a couple of rivets. The epoxy and rivets bonding the strip to the frame will again form a very strong shear force to stop bending at that point. To illustrate my point...if you have ever built a piece of furniture or cabinet that come broken down in a box it was pretty flimsy until you attached the backing which is generally a piece of 1/8 inch fiberboard that is pretty flimsy in itself. Once the backing is attached to the frame you could stand on it and it will not bend. One more point when I searched the Forums about bent doors another problem came up and that is if you take the door off the trailer and then reshape it the hinges may not line up when you try to reinstall it. So I'm going to do mine with the door open but mounted on the hinges on the trailer.
door frame, racked door, replace
