Old 11-01-2005, 07:47 AM   #1
1986 34' Limited
Prospect , Tennessee
No Potable Water Key
After recently purchasing an Airstream (1986 34 Limited) and trying it out in campgrounds where I used their water, I lately just found that in the bunch of keys I received from the seller that I do not have the key to open the potable water tank (hadn't needed to do that before now). Although they are looking, I suspect they will not find it. How do you get a replacement key that will work when you do not have one? In my manual, there are pictures of the different keys. Is there some sort of code in there that will tell which key to get, besides just showin the type of key?
Lee
Full Time.....keeping the shiny side up
Lee Davis is offline   Reply With Quote
Old 11-01-2005, 07:58 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
There is not a lot of difference and discrimination between each individual key. The PO of my Argosy just pulled out a box of 20-30 keys and tried a few. I now have 4 single keys, each with an individual function. On a couple I can tell the tumblers aren't working the smoothest but the keys still work.
Many people reply about the advisability of having a locksmith replace the locks so that you can actually have a duplicate set. It's supposedly not very expensive, especially if you drive up to the place of business. I think I'd try to match the keys for most of the access doors, keeping a separate key for the trailer door. I'll do this lock replacement before I have my single keys copied.
5 meter Langford Nahanni
Old 11-01-2005, 08:19 AM   #3
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Try Oasis RV
hi- I got a key for my water door, made by thetford, from Oasis RV in Tucson. Good luck- tim
tphan is offline   Reply With Quote
Old 11-07-2005, 08:10 PM   #4
grantb4's Avatar
2005 22' Safari
San Juan Capistrano , California
Angry
Funny -- I have the same problem on a NEW airstream. I have to go by the dealer some day and try and get one...
GB
grantb4 is offline   Reply With Quote
Water problems Dbraw Fresh Water Systems 14 10-03-2009 02:15 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Water inlet key replacement Road Ruler Fresh Water Systems 7 09-03-2002 09:07 PM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
