Old 09-07-2018, 06:17 PM   #1
Belgrade , Missouri
New keys for door lock
Where can I get new keys for Air Stream? Where can I get the blank for the exterior door? My hardware store said they could make a new one if I could get a blank.
pgyount is offline   Reply With Quote
Old 09-07-2018, 07:01 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
What trailer do you have?
Old 09-07-2018, 07:44 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If you have a modern trailer you can get the blanks from JC. Just how far back "modern" goes .... it depends a lot on just what you happen to have.
Old 09-07-2018, 08:12 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
CH 751 keys are pretty popular for older units. Blanks are available on the internet.
Old 09-07-2018, 09:32 PM   #5
chicagoair's Avatar
2019 19' Flying Cloud
Chicago , Illinois
If Jackson Center doesn’t have what you need the Airstream Life store also sells blanks: https://store.airstreamlife.com/coll...ntry-door-keys
chicagoair is offline   Reply With Quote
Old 09-08-2018, 06:55 AM   #6
Belgrade , Missouri
2000 Safari SE 20 ft.
Old 09-08-2018, 10:18 AM   #7
2008 19' International
Kingsport , Tennessee
Had to do the same thing! You can order the keys from the Airstream store. There should be a number on each key that will help them determine the correct key or blank key for you!
ImaTarHeel is offline   Reply With Quote
Old 09-08-2018, 10:36 AM   #8
2018 23' Flying Cloud
Eagle Creek , OR
Send a message via Skype™ to almcate
Don't know about 2000 keys, but TriMark key sets for my 2010 were not only are difficult to find, they're hard to cut accurately so don't ask your hardware store to cut, take to a locksmith to cut the blanks you obtain.
Question: better to be a successful pessimist or a failed optimist?
Al & Robin
2018 Airstream 23FB Flying Cloud
2015 F150 XLT 3.5L EcoBoost, 4WD
almcate is offline   Reply With Quote
Old 09-08-2018, 11:16 AM   #9
2018 27' Tommy Bahama
Orange , California
I went to my local Airstream Service shop and purchased mine. Good luck
Lucy Goosy is offline   Reply With Quote
Old 09-08-2018, 11:45 AM   #10
2019 Nest
Omaha , Nebraska
Airstream keys
Call TriMark 1-800-431-8616 and give them your trailer year and model, as well as the number that is on your key, and they will send you an already cut key using the number code on your key for $4 or $3 for an uncut blank plus shipping which is nominal. They are in Iowa and very fast on delivery. Airstream did not have blanks for my Nest trailer yet, so I called TriMark directly and got great service.
Beboplu is offline   Reply With Quote
Old 09-08-2018, 01:30 PM   #11
1973 31' Sovereign
1978 Argosy 30
1985 31' Excella
Sacramento , California
I think they are Schlage Key s and you can get new ones made for your door lock if you know the number from them or have one that still works to get a second one made...
If you don't have the keys... here is what you can do... Airstream has a build list.. i.e everything they put into your unit... and they have the model and S/N of the units... this includes the LOCKS...
Thus if you have the orginal paper work for the trailer.. it should be on a card that came with it... if not... call airstream and get them to fax or email you a copy of the build list card that they should have on file... when they built the trailer...
On this then it has the KEY code... i.e you can take that to the locksmith and for a couple of bux... they can make a key from it... and they should work... I did... after the guy I got mine from .. said he didn't have any of the keys... for the door lock... but, we found the build list in the owners manual stuck in their.. and took it to the locksmith.. he made two keys... and a master... and they all worked... cost was around 30 bux for all...
If you don't have the key code.. or key... then the locksmith that deals in the manufacturs key... can come use his tools to find the number... by picking it...
...but... its real expensive... about 150 bux to have him come do that... So I would try and find the key code or get it from Airstream... as you only need the vin no... to get them to look up the trailer and get you the info you need...
Good luck...
G.M>
GM Airstream is offline   Reply With Quote
Old 09-08-2018, 02:41 PM   #12
369goose's Avatar
2014 25' Flying Cloud
1987 29' Sovereign
1977 31' Sovereign
Tampa Bay , Florida
Ditto ☝️
Definitely use an experienced locksmith.
☘ 369goose
"The world is a book and those who do not travel read only one page.” – St. Augustine
369goose is offline   Reply With Quote
Old 09-08-2018, 03:09 PM   #13
Cayce , South Carolina
I had two cut today at my local Ace Hardware store key is AP1 HY-KO key. Door knob best I can tell original on 1961 Overlander.
Buzz1967 is offline   Reply With Quote
replacement keys for main door lock (have number) nickglase Classic Motorhomes 8 06-22-2017 05:50 AM
New, never installed Bargman L-77 lock with 2 keys montanablue Airstream Classifieds 2 05-11-2017 04:55 PM
exterior door latch/lock/keys from 1992 Airstream Skatiero Airstream Classifieds 0 12-26-2013 08:26 PM
'65 GT Main Door Lock / Lost Keys Chiefy Doors & Locks 3 01-10-2010 05:34 PM
