Old 05-17-2007, 08:18 AM   #1
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
New flush lavatory door latch
Thought I'd mention to a wider audience: there's some good information in another thread (pics in post #8, info starting around post #24) about the newer flush lavatory door latches, recently introduced from the factory during the 2007 calendar year. Pictures, prices, ordering details, installation details...
These replace the giant hook-style door handles that have a tendency to "grab" you when you come too near
Bottom line: ordering through a dealer from the factory is literally twice what you'd pay by using the latch manufacturer's parts system.
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 05-17-2007, 08:31 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
jd -- I've been following that thread. Nobody has quite said it -- does the cutout in the door have to change much? I'll have my Safari in the drive later this morning and will post a pic of the old latch cutout.
5 meter Langford Nahanni
Old 05-17-2007, 10:58 AM   #3
just jd.
5cats's Avatar
2007 20' Safari SE
"Bob M" didn't indicate any problems with the existing cutout (in the linked thread) when he posted that he did the conversion. I think he only widened the stike plate hole slightly?
I plan to document my conversion with pics (latch shipped yesterday) in this thread...
Bob, I was a bit hesitant about starting this thread, by the way. On the one hand, the linked thread was getting hijacked a bit. On the other, I'd really like to have all the pertinent info in this thread -- but didn't want to duplicated postings. Do you suppose it'd be more helpful to just post specifics here, too?
Cheers,
-jd.
Old 05-17-2007, 08:54 PM   #4
janetb's Avatar
2007 25' Safari FB SE
Santa Cruz , California
Thanks for getting this "project specific" thread going 5cats. I hope the new handle will take the same bore as the lever. If not, I'm sure we'll find a way to make it work (royal "we" yet again...) and will post our before and after, with any necessary modifications.
And many thanks to Bob for the intallation details.
Janet
janetb is offline   Reply With Quote
Old 05-22-2007, 07:58 PM   #5
B4WEDI's Avatar
2006 19' Safari SE
Nawthin' , Hemisphere
Yeah Bob, ( and others listening ) from what I see, there is going to be a BIG change from the 2" round hole that is existing in your door now, but it will work.
A rectangular notch will have to be cut out of the door approx. 4.5" deep X 2.5" tall to accept the new hardware. Use the existing hole for your centerline layout and you should line up nicely with the receiver in the jamb when done.
A pencil, a measuring stick, a mitre square, a sharp finish handsaw, a dremel tool, a drill with some bits, a phillips head screwdriver, a rasp and maybe a new single edged razor blade will be about all it will take to put you on the right path.
From what I understand, the new hardware does not come with any fasteners, so a trip to the store may be in order for something nice if you don't have anything on hand.
Remember, it is a hollow door and since there is a hole cut out of it already, once you cut through the edge of the door and reach the existing hole, the sheets will lose some rigidity and want to walk around, so ya gotta be firm and decisive, but go slow and easy. If you tape your lines, you will reduce chipping the edge of the veneer when you saw.
If you save the door edge blocking that you cut out of the leading edge, you can glue the pieces inside the door at the back side of the new hole you just cut, to stregthen the door at the rear of the new hardware where the fasteners will be. They will be the correct thickness if you shave the plastc wood grain veneer and door skin from the blocks with the new razor.
Measure thrice, rethink your layout and cut once........ or twice if ya have to,
No shame in that !
Good Luck !
*** KEEP LOOKING UP ***
T & K
B4WEDI is offline   Reply With Quote
Old 05-22-2007, 09:18 PM   #6
Here's a pic of the original Captain Hook latch cutout:
Name:	bathroom latch cutout.jpg
Any photo of the flush latch installation would be great. I'm in a stretch of being alternately home and away in about 3 day lumps -- I've got both these threads bookmarked and intend to get back to it. Good going so far!
Old 05-23-2007, 08:27 AM   #7
just jd.
5cats's Avatar
2007 20' Safari SE
My Latch just arrived last evening. As suspected, no screws. I had expected some install instructions, but there are none.
Anyone have a link to the install instructions? I plan to tackle this over Memorial Day weekend.
Cheers,
-jd.
Old 05-23-2007, 08:35 AM   #8
B4WEDI's Avatar
2006 19' Safari SE
Bob, Pretty much all the door material behind the plate you are showing in your picture will have to be removed and then some.
4.5 " back from the edge of the door and another 1.25 " up and down from the center line of the existing 2" hole.
T & K
Old 05-23-2007, 09:47 AM   #9
B4WEDI's Avatar
2006 19' Safari SE
The BIG picture
The new latch is a slide mechanism and needs room to move.
here are a couple illustrations.....
ID:	37796   Click image for larger version
Name:	New Latch Notch.JPG
Name:	Inside latch in place.JPG
ID:	37798   Click image for larger version
T & K
Old 05-23-2007, 11:48 PM   #10
just jd.
5cats's Avatar
2007 20' Safari SE
install tip/guide
I downloaded the install tip/guide from the manufacturer for the latch. There's not a lot of detail, but better than zero. This is for a family of latches; I think the third and fourth pages cover the latch we're talking about here.
MR.en.pdf
B4WEDI's pictures are a terrific help, thanks!
Q: Did the inside nylon bumpers need modification for the door to close properly?
Q: It looks like the leading edge of the door has an solid 1x interior -- that true?
Cheers,
-jd.
Old 05-24-2007, 08:40 AM   #11
B4WEDI's Avatar
2006 19' Safari SE
Glad they helped........
Yes, they adjust the amount of play between the door and the inside jamb and helps with the alignment of the catch and receiver in the jamb. They not only affect how much oomph you need to close the door, but will also reduce the amount of free play the door has to bounce back and forth as you travel down the road. A sharp razor will remove thin slices of the little rubber nibs till you get the desired amount of wiggle room.
Right again ! Good Luck !
T & K
Old 05-24-2007, 01:48 PM   #12
B4WEDI's Avatar
2006 19' Safari SE
As an alternative...... Attn: janetb
For those of us who are more concerned with function over form and can live without the "correctness" of this very expensive latch .......
There are a host of alternatives as close as your local harware store or of course online. Just look for Privacy Latches for Pocket Doors.
No carpentry skills needed. You will likely be able to use the same 2 1/8" hole that exists in your door now and spend no more than $ 20 bux for something nice yet functional.
Make sure the one you get fits the thickness of your door or can be adapted to it. As an added bonus, you will be able to put back "Captain Hook" if you so desire one day !
http://www.thehardwarehut.com/images...3pk1-thumb.jpg
T & K
Old 05-25-2007, 11:49 AM   #13
just jd.
5cats's Avatar
2007 20' Safari SE
Reconsidered...still proceeding
[*snipped* more excellent comments]
Thanks for that, and I agree.
This gave me great pause, and I took time to reconsider performing this mod. (I even had to stop listening to the new VAP podcast to write this...go Tim, Rob, and Colin!)
  • The new latch is pricey @ seventy bills.
  • The new latch looks surprisingly oversized upon delivery.
  • Substantial cutting is required.
  • This mod is irreversible.
  • Cheaper, easier, less invasive, reversible options are, in fact, available.
For me, at this point:
  • I have already paid for and received the new latch (so I had already decided the price was not a deal-breaker).
  • Holding the new latch up against the door, I can see it looks fine (to my eye), without looking disproportionably large. This is considerably helped by the fact that my Safari has a huge mirror covering virtually the entire upper half of the door. A little bling right next to it is hardly noticed.
  • I've already performed significant mods (redo wiring, battery monitor, fantastic fans, accumulater tank...) and this doesn't look too intimidating.
  • Once installed, I don't plan on ever separating the door latch from the trailer, except possibly as a salvage operation (hope not!)
Had I not already obtained the new latch and considered other options, I'd go the other route. Having the new latch, I'm happy with it. And so I am proceeding with the install, and plan to tackle this project tomorrow
I'll be posting pictures, for sure.
Q: What's the optimal screw size? looks like it might be #10 x 3/8 SS flathead, or maybe #8?
Cheers,
-jd.
Old 05-25-2007, 02:26 PM   #14
B4WEDI's Avatar
2006 19' Safari SE
5cats.....
I found SS # 6 's X 1" wood screws for the door edge worked fine and recessed more cleanly in the hardware. The heads of # 8's protruded some on the piece I worked on.
Because there is nothing much to screw into at the rear of the latch, I opted for a fastener like the one pictured below. As I said earlier, the piece of door edge that you removed from the front could be glued between the door skins at the rear to beef it up and have something to fasten to.
Honestly, It ain't that big a job and with your past experiences and skills, you'll have no problem. Good luck with your project and enjoy the Holiday !
T & K
No Fuss Flush Leaks! dpope 2003 Safari 7 06-25-2005 02:48 PM
Tranny 'flush' or Filter change Sav'h Steve Mechanics Corner - Engines, Transmission & More... 18 04-02-2004 08:22 PM
How to add a b/tank flush system inthwind Waste Systems, Tanks & Totes 2 06-25-2003 09:59 AM
Flush out connection JLD Waste Systems, Tanks & Totes 2 01-04-2003 09:06 PM
Black water flush davidz71 Waste Systems, Tanks & Totes 14 04-28-2002 04:15 PM
