Old 04-02-2014, 03:36 PM   #1
Lexxy's Avatar
1973 23' Safari
Brevard , North Carolina
Images: 16
New finish on old front door latch
The silver coating....looked like chrome....was over 50% flaked off the front door knob on my 73 safari. I scrubbed the corrosion off and most of the silver off with Dremel. I know the bare aluminum will get hands dirty since it loves to oxidize.
What kind of coating can I put on this handle. Clear coat or polish or wax or actual paint. I don't want to spend a lot or take it off. It works fine and I'm afraid I won't get it back right. It doesn't look too bad...only a hair better than flaking silver.
I did search this and read a whole bunch of posts that didn't help.
Lexxy
After circumnavigating on 40' sailboat, cruising the USA in our '73 Safari, Tara!
Lexxy is offline   Reply With Quote
Old 04-02-2014, 03:45 PM   #2
1981 31' Excella II
New Market , Alabama
The material under the chrome is probably an aluminum-zinc casting (pot metal). It will turn a gray color and should not come off on your hands. You can polish it but I think it will turn gray again. You can use a zinc-chromate (etch primer) and a top coat of paint like auto spray touch-up paint.
Perry
Old 04-02-2014, 05:34 PM   #3
Lexxy's Avatar
1973 23' Safari
Images: 16
I went all the way to the aluminum cuz it was pimpling up all over with corrosion bumps. What is clear coat on the aluminum body? Can I get that. My unit has never been polished and looks brushed so I think the clear coat is pretty ok....enuf anyway! I just thought I should finish the handle somehow.
Lexxy
Old 04-02-2014, 07:24 PM   #4
1972 27' Overlander
Denver , North Carolina
Not sure of you had a door knob. My 72 has a Bargman latch.
mccrosti is offline   Reply With Quote
Old 04-02-2014, 07:27 PM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The handle is not aluminum and will quickly discolored, if not painted. Some people paint, as the previous poster said. I would suggest you use automotive chrome or metal flake aluminum. I am not sure clearcoat will be enough to protect it.
Old 04-02-2014, 07:46 PM   #6
Lexxy's Avatar
1973 23' Safari
Images: 16
That metal polishes up just like aluminum. It is the original latch like the photos I've seen but I will pursue an automotive paint. Thanks
Lexxy
Old 04-02-2014, 09:06 PM   #7
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Re-Chrome
Lexxy, Search your area for a local plating company and see what the cost would be for you to have it plated back to the original finish. This method will hold up much longer than painting and/or clear coating. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 04-03-2014, 07:23 AM   #8
1981 31' Excella II
For what it would cost to chrome the old knob he could have one made out of solid stainless steel.
Perry
Old 04-03-2014, 02:37 PM   #9
Lexxy's Avatar
1973 23' Safari
Images: 16
If I had it replanted, I would have to remove it. We just want an ok fix. Our unit is not a showpiece....just a camper. Thanks, I got the primer and spray paint at an auto place today. Just need a few spring days with no chance of rain.
Lexxy
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 18 03-23-2014 10:49 AM
'78 Argosy Front Door Handle / Lock / Latch Markeyro Doors & Locks 8 08-19-2013 02:56 PM
Old, old, old airconditioner removal bilby05 Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-17-2012 04:19 PM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
door in door latch richie rich Exterior Storage Compartments & Access Doors 3 10-07-2009 09:02 PM
