Old 06-25-2011, 05:36 PM   #1
withidl's Avatar
2002 31' Classic
Houston , Texas
Need a Little Privacy?? - PLEASE!!
For a long time I’ve been scheming for a simple way to lock the sliding bathroom door on my 2003 ASCL 31 foot. Scheming complete, the following is my “locking pin” solution with photos:
1/8” brass rod
1/8” drill bit
Hack saw
400 grit emery paper
Mother’s aluminum / magnesium polish
First, measure twice, drill once so as to NOT go through the door on the hall side!
That being said, I cut the brass rod to a working length of about 12”.
I then rounded the rod end so that it would easily insert into a 1/8” hole drilled into the bathroom wall and TIGHTLY CLOSED door just below where the plastic “travel” strap anchors (mark the drill bit with tape just short of wall/door depth to assure non-penetration of the door on the hall side.
With a vice and large round rod of suitable diameter bend the 1/8” brass rod into a loop around the large rod such that from the rear of the loop to the end of the rod is about 3”. Cut off excess 1/8” rod in a cosmetic way; twist the loop into the same plane as the rod; cut off and file the excess; wet sand with 400 grit wet/dry emery paper and polish off the whole thing with Mother’s aluminum / magnesium polish.
Punch a hole in the loop end of the door “travel” strap and insert the locking pin through the strap loop and into the pin loop for hanging convenience when not in use.
Name:	Bath Door Locking Pin 1.jpg
ID:	133245   Click image for larger version
Name:	Bath Door Locking Pin 2.jpg
Name:	Bath Door Locking Pin 3.jpg
ID:	133247   Click image for larger version
Name:	Bath Door Locking Pin 4.jpg
Name:	Bath Door Locking Pin 5.jpg
withidl is offline   Reply With Quote
Old 06-25-2011, 05:38 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
That's quite clever
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 06-25-2011, 06:31 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Neat! However, if the door is closed.....how is privacy compromised? You must have kids running around...
Old 06-25-2011, 07:45 PM   #4
withidl's Avatar
2002 31' Classic
Houston , Texas
No little kids, only my sons (22 & 26) and their friends. The problem is when the bathroom is being used during the day (no light seen under the door), unless there is some sound coming from it when another person wants/needs to use it, there is nothing to stop them from just sliding the door open thinking that the last to use it just closed it, as it is normally kept closed so as not to heat or cool it; and no one likes to be inadvertently "exposed".
Old 06-25-2011, 07:57 PM   #5
1977 Argosy 24
Milltown , Wisconsin
Get over it! If someone sees something they have never seen before, they can scream!!!
ventport is offline   Reply With Quote
Old 06-25-2011, 08:01 PM   #6
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Clever idea.. ours is a pass through.. so I need two of them!
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 06-25-2011, 08:15 PM   #7
withidl's Avatar
2002 31' Classic
Houston , Texas
My older son's girl friend traveled with my younger son and me to meet him at Ft. Leonardwood last August; had to be careful; don't like to have to be careful.
Old 06-25-2011, 11:25 PM   #8
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, that is a great idea; I can't believe that Airstream didn't think to put a latch on the bathroom door. [actually I can believe it]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-26-2011, 04:29 AM   #9
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Or they might appreciate it. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 06-26-2011, 05:59 AM   #10
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Scream works....DW could stop a charging Wildebeast !!!
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 06-26-2011, 10:17 AM   #11
withidl's Avatar
2002 31' Classic
Houston , Texas
The door design doesn't really lend itself to the installation of a "normal" interior latch. I spent some time at Home Depot trying to visualize adapting off the shelf designs to no avail; had to become creative.
Old 06-26-2011, 11:10 AM   #12
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Shame the kids never learned to knock.
You can cure them by making a point of barging in on their "privacy".
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 06-26-2011, 11:45 AM   #13
withidl's Avatar
2002 31' Classic
Houston , Texas
Pat
Awww, two wrongs DO make a right?
I would hazard a guess that with very few exceptions the bathrooms in all homes have doors that lock; therefore most people ASSume if the bathroom is occupied the door will be locked. Also, as previously stated, I keep the bathroom door closed to minimize the cooling and heating load so a closed door does not signify bathroom usage.
If all bathroom doors never had locks Im sure there would be a whole lot of knocking going on.
Apps/Pandora under investigation Denis4x4 Computers, Internet & Satellite 0 04-05-2011 06:41 AM
