Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 03-18-2013, 07:35 PM   #1
texasbound's Avatar
Bothell , Washington
missing screen door slide?
Anyone know where I can get the aluminum number that goes in here?
Thanx
-=TexasBound=-
1974 - 31' Airstream Sovereign Land Yacht "Dudley"
WBCCI # 7616
https://ismelltexas.wordpress.com
texasbound is offline   Reply With Quote
Old 03-18-2013, 07:53 PM   #2
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
I believe it is plastic, not aluminum. It is called a bug guard and should be available at Inland RV. I ordered one from there for my '82 several months ago. they are oversized a litte bit; just trim to fit.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 03-18-2013, 08:04 PM   #3
Yep, oversize they are because of the variance in the screen doors.
Thank you.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-18-2013, 08:33 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
They are plastic...now. Any Airstream dealer should be able to get you one.
Aaron
WBCCI #XXXX AIR #2495
Old 03-18-2013, 09:04 PM   #5
Aaron
Aaron.
Unfortunately, most Airstream dealers stock very few parts, and of those, even more do not stock parts for anything but the new coaches.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-18-2013, 11:48 PM   #6
texasbound's Avatar
Well I got the plastic one but it was too thick fir the track.... are there different thicknesses?
Thanx
-=TexasBound=-
WBCCI # 7616
Old 03-19-2013, 03:43 AM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Thanx
Yes, I shaved the edges down on mine with a piece of sandpaper. I bought one from Camping World for my 1981 and it was thicker than the one I bought from Airstream for my 1975. I believe it may have been a generic part the AS bought from an outside vendor and the manufacturer has changed.
Aaron
Old 03-19-2013, 05:14 AM   #8
Retired.
. , At Large
The original thin ones would distort and fall out, or break. The newer, thicker ones last longer.
Old 03-19-2013, 06:46 PM   #9
Thanx
Taper the edges down slightly and it will fit just fine.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-19-2013, 11:54 PM   #10
texasbound's Avatar
Thanx Andy. I'll give it a try.
-=TexasBound=-
WBCCI # 7616
Old 02-23-2015, 07:45 PM   #11
1976 Argosy 30
Annapolis , Maryland
Screen Door BAD Idea
This can't be what my '76 Argosy screen door is supposed to look like, not to mention that it is dangerous and won't close when the door is closed. Is the plastic slide mentioned on this forum from Inland RV what I need?
Name:	2nd Screen Door.jpg
kaa4111 is offline   Reply With Quote
Old 02-23-2015, 08:21 PM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Certainly not original. I believe replacements are available from VTS or ODM. Inland could have them as well.
Old 02-23-2015, 08:56 PM   #13
1976 Argosy 26
Houston , Texas
Its called a Gizzy.
wzelkins is offline   Reply With Quote
Old 02-26-2015, 08:55 PM   #14
1976 Argosy 30
Appreciate all the help. Love the name "Gizzy".
