Old 08-06-2011, 03:21 AM   #15
1986 27' Sovereign
Tellico Plains , Tennessee
Thanks John,
You did a great job on making the exterior door handle for my 1986 Sovereign.
Judy
belaca is offline   Reply With Quote
Old 07-21-2012, 03:07 AM   #16
1988 29' Excella
Campbell , California
I need a new handle as well. Left a PM for John, awaiting reply.
K9GVF is offline   Reply With Quote
Old 03-29-2013, 07:49 PM   #17
1983 31' Limited
Tallahassee , Florida
Need new handle!
Hi John...are you still making entry door handles? We have a 31 foot 1983 Airstream travel trailer with a broken entry handle (big surprise). How much do you charge for the replacement? Also, there is a crack on the inner plate around the inside handle. Have you had anyone ask about a replacement or repair for that? Thank you! Kim
JoeKim is offline   Reply With Quote
Old 03-31-2013, 09:09 AM   #18
1988 29' Excella
Sometimes it is not the handle
... but the tabs on the internal slider plate that pulls the bolt back.
I ordered one of John's handles - a work of art... but it is the wrong dimensions for my 1988 Excella. I also ordered the entire mechanism with filler plates just in case.
While stressing over whether or not to bite the bullet and do the new lock mod I took apart the original lock and determined that the protuding tangs on the door handle were OK, they simply had nothing to make contact and pull the bolt back.
See picture... obviously the metal tabs are gone. Look to either side of the oval hole in the middle. The irregularities in the squarish holes are evidence something was there.
I would have had my neighborhood "metal magician" weld on new tabs but he was off in the Baja racing his buggy so I had to get creative, at least temporarily.
Just above the square holes is barely enough room to put replacement tabs of sorts. I could have used some small angle brackets, but opted for a pair of 1/4" hex standoffs.
I removed the plate, drilled and countersunk (on the back side) holes for flathead 6-32 screws. Mounted the standoffs of the front side - tah-dah! Good as new.
Apparently I do not have pics of the disassembly, drilling, etc. but a pic of the final result as seen from the handle-view.
I hope, if you can get it all apart, you can figure out what I did.
Replacement plates may not be too difficult to make - if you can find someone will to take the time to probably laser or water-jet cut all the holes, etc. but I think welding on a new stainless tab may be cheaper, quicker and easier.
This does not help the possibility that my handle will eventually break
ID:	182174   Click image for larger version
Old 08-08-2013, 12:35 PM   #19
1983 34' Limited
Christchurch , Canterbury
Hi John,
I need a new door handle for my 1983 Limited. Please send me contact information.
Tony
Tony Burton is offline   Reply With Quote
Old 08-08-2013, 05:49 PM   #20
1981 31' Excella II
New Market , Alabama
I have been making the Keeler brass door handles on a limited basis. I don't have any at the moment but that may change. PM me if you want details.
Here is a related thread.
http://www.airforums.com/forums/f453...dle-87188.html
Perry
Old 08-09-2013, 05:27 PM   #21
1986 27' Sovereign
Mogadore , Ohio
Originally Posted by Tony Burton View Post
Hi John,
Tony
Hi Tony, Yes I have a stainless handle that may fit your limited. The handle should fit trailers 1978 to 1993 but there are a few exceptions. The easiest way to tell is the size of the handle - mine is 2" wide x 4" high. if you could verify this we can go from there. Contact me at j.boxmaker@sbcglobal.net.
John
John Burkey is offline   Reply With Quote
Old 01-20-2014, 01:40 PM   #22
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Originally Posted by John Burkey View Post
Hello,
Just to let yoy guys know, I make a stainless steel replacement handle for 1978 to 1993 entry door. I made the first one for me and decided to make it available to others.
I just replaced my broken handle with one of John's stainless replacements. Excellent workmanship plus dummy-proof instructions. Thank-You John. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 03-30-2014, 01:05 PM   #23
Full-timer
nickglase's Avatar
1988 34.5' Airstream 345
new york , New York
Hi John,
Our handle just broke here and we'd be interested in one of yours.
I'm at nickglase@gmail.com .
Nick
Urban camping in San Francisco, Ca
1988 Airstream 345 Motorhome
1964 Vespa GS
1982 VW Qauntum, turbo diesel
1979 Triumph Spitfire 1500
nickglase is offline   Reply With Quote
Old 07-13-2014, 11:51 AM   #24
1978 31' Excella 500
Eden , Utah
I also need a paddle handle for my 1978 Excella 500 how do I get in touch? My e-mail is bajabill@digis.net
Thanks in advance.
BajaBill is offline   Reply With Quote
Old 07-13-2014, 12:19 PM   #25
noreen&sal's Avatar
1981 27' Excella II
Ours broke in Jan. we got in touch with John Burkey. His e-mail address is j.boxmaker@scbglobal.net. If you don't get a response PM him. Noreen
Sal & Nora
AIR 42483
TAC N.J. 17
WBCCI 24740
Old 07-14-2014, 09:51 AM   #26
de NO1PC
JimAspinwall's Avatar
2004 30' Classic
1988 29' Excella
FYI - none of the available handle/lock replacements fit or seemed suitable for our 88 Excella, of which the problem was NOT the handle itself but the two 90 degree tabs on the slider plate inside the mechanism - the ones the tangs on the handle contact and slide against to pull the mechanism/bolt back.
My fix, as a quicker/easier option than having two new tabs fabricated and welded onto the plate, was to screw on two 1/4" metal standoff blocks onto the plate where the tabs were, countersinking a flat head screw on the backside of the plate. The handle tangs have adequate contact area to pull on the standoffs and shift the plate/mechanism freely. I dare saw the standoffs probably aren't going to bend or break off before the tangs on the handle do, for which there is no fitting replacement, close, but not usable.
I may have pictures someplace.
Enjoy the ride! Best 73!
de Jim, NO1PC
JimAspinwall is offline   Reply With Quote
Old 07-14-2014, 12:24 PM   #27
1981 31' Excella II
Here is a thread where a guy made a new plate with the tabs on it. I think he did a real good job with it.
http://www.airforums.com/forums/f453...ck-122041.html
Perry
Old 07-21-2014, 06:12 AM   #28
Full-timer
nickglase's Avatar
new york , New York
Although I'd highly recommend John's handles (they look superior), I ended up buying interior and exterior hardware from the OEM manufacturer, TriMark. These parts are discontinued but many of them are still available for purchase via ebay.
These fit my 1988 345 motor home:
Trimark Door Handle And Lock Assembly 11298-35-RH (interior side lock and latch)
TriMark series 030-0450 / part number is: 11812-37 (exterior latch)
1964 Vespa GS
1970-1977 Main Door Lock gvanman Doors & Locks 64 05-15-2015 08:44 PM
How does the main-door hold-back work? monocoque Exterior Storage Compartments & Access Doors 3 03-20-2008 03:55 PM
main door hinge technautica Doors & Locks 0 09-17-2004 05:34 PM
Main door problems Silvertwinkie Our Community 8 03-02-2003 11:46 PM
1965 Main Door buckmaster 1965 - 1969 Globetrotter 0 10-19-2002 07:47 PM
