Old 08-28-2011, 10:56 PM   #1
2009 23' International
Boulder , Colorado
Lubrication for front door Locks and Hinges
Hello,
Its about time I lube my locks and hinges. Do any of you have suggestions for oil type/brand and what to stay away from / not use.
This would be for a 2009 model
Thanks!
Tom
tmarquis is offline   Reply With Quote
Old 08-29-2011, 03:49 AM   #2
r carl's Avatar
Lin , Ne
Graphite powder in the lock where the key goes in and 3in1 oil on the hinges and a thin film of grease on the latch bolt is what I do.
Old 08-29-2011, 06:36 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
The old standby.....water displacement forty.
Also works great for.......never mind.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 08-29-2011, 06:57 AM   #4
Originally Posted by tmarquis View Post
Hello,
Thanks!
Tom
Silicone spray, has done the job for over 40 years.
Old 08-29-2011, 07:33 AM   #5
withidl's Avatar
2002 31' Classic
Houston , Texas
I agree, WD-40. Just stick the little spout wherever it will go (into the key hole, into the lock mechanism, etc.). Squirts a viscous oil cut with propane which leaves the scene.
withidl is offline   Reply With Quote
Old 08-29-2011, 08:30 AM   #6
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
even better, Lock Ease, in the bottle, or spray can.
work your key in & out, and turn a few times after applying!
AGS Company - Lock-Ease Graphited Lock Fluid
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 08-29-2011, 08:50 AM   #7
Crusty's Avatar
1992 34' Excella
Like Andy says, use a silicone spray lubricant because it's a dry lubricant. Oily lubricants stay wet and collect dirt which will eventually clog the mechanism and make it stop working and possibly even break.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 08-29-2011, 10:05 AM   #8
Boulder , Colorado
Yeah I like the silicone spray idea. I see a lot of aluminum dust and dirt that seems to collect anywhere near oil.
Thanks!
Old 08-29-2011, 10:40 AM   #9
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
If you want a sticky mess that will require complete disassemble and cleaning at some point then WD-40 is great, otherwise use silicone spray or any of the other above suggestions. Even spray paraffin designed for dry lube is better than WD-40. Previous owner of my '94' Wrangler used WD-40 in the locks and I am still cleaning that junk out. WD-40, great for what it was intended for, rotten for lubrication.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 08-29-2011, 12:30 PM   #10
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Silicone spray, any lock all the time
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
doors, locks, lubrication
Door Hinges look tired Del Gurney Cleaning, Stripping & Polishing 5 10-22-2012 11:38 PM
Basement storage compartment hinge lubrication. BarnacleBill Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 05-03-2011 04:35 PM
Door Hinges dlb56hdt All Argosy Trailers 2 04-05-2011 08:42 AM
Door hinges shepherd57 Classic Motorhomes 7 04-04-2011 01:35 PM
