Old 08-23-2017, 07:55 PM   #1
Carrma's Avatar
2015 27' FB International
stow , Ohio
Lubricating Main Door Hinges
A/S Question
Hinges are creaking and need to be lubed. Have heard not to use WD-40 as it leaves a film. What is best product to buy and use for this application.
Thanks, Mike
Carrma is offline   Reply With Quote
Old 08-23-2017, 08:10 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Silicone spray.
MICHAEL
Old 08-23-2017, 08:13 PM   #3
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Originally Posted by AWCHIEF View Post
Silicone spray.
Is there anything related to lubrication for which silicone spray should not be used? It seems to be the go to solution on anything needing lubrication.
Old 08-23-2017, 08:55 PM   #4
dznf0g's Avatar
Oswego , Illinois
I use dry lube. Mountain bike dry chain lube is my go to wherever I don't want to attract dust and grime.
-Rich-
Old 08-23-2017, 09:02 PM   #5
2016 25' Flying Cloud
Holly Springs , Mississippi
Try Rem-Oil. It's much better than WD-40 and seems to hold up better (i.e., lasts longer) than silicone sprays.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 08-23-2017, 10:20 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
WD to clean only. Gun oil made to handle environmentals. Also, I use LPS 2.. it is an industrial lube, spray and bulk. Also good for MC cables.. after WD clean and flush.
LPS works on weapons too... the 1 is light.. 2 then 3 heavier weights. The 3 stays on longer so fewer dribbles. Just wipe off to keep clean.
There is now Teflon spray but I cannot say how that works on hinges.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-23-2017, 10:28 PM   #7
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We use Houdini, a professional lock lubricant.
Brian
SuEllyn & Brian McCabe
Old 08-24-2017, 12:20 PM   #8
greenflag's Avatar
2016 30' International
Quartz Hill , California
I use silicone spray. it doesn't attract dust and grime.
greenflag is offline   Reply With Quote
Old 08-24-2017, 12:29 PM   #9
Mollysdad's Avatar
Three in One oil?
I always seem to have a can sitting around. Can seals tight.
The problem with a spray is a hinge needs for the lube to find it's way down into the hidden recesses of the pin. I like a very light oil, including a gun oil like Eezox.
Old 08-24-2017, 04:56 PM   #10
RJJ
RJJ's Avatar
2016 26' Flying Cloud
2016 20' Flying Cloud
St Petersburg , Florida
Originally Posted by Carrma View Post
A/S Question
Thanks, Mike
I use white lithium grease.
RJJ is offline   Reply With Quote
Old 08-24-2017, 05:02 PM   #11
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
As said, WD-40 is not a lubricant. Silcone is a short lived one. That being said, it's pretty easy to lube the hinges fairly often.
I use Corrosion-X.
2012 Dodge Durango Hemi/AWD
Old 08-24-2017, 07:46 PM   #12
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Three in One.
MelGoddard is offline   Reply With Quote
Old 08-24-2017, 08:10 PM   #13
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Don't use silicone around areas you may later want to paint, clear coat, or seal. It will have to be abraded off, unless a lot of time passes for the elements to dissipate it.
guskmg
Main Door Hinges - 1964 jomama 1960 - 1964 Globetrotter 10 06-26-2018 01:10 PM
Door Hinges converted to Piano Hinges Ray Eklund Cabinets, Counter Tops & Furnishings 15 05-11-2017 12:57 PM
lubricating door latches StreaminGeo Doors & Locks 5 06-05-2016 04:14 PM
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Lubricating the hitch jack? Kistler Jacks, Stabilizers, Lifting and Leveling 5 07-26-2012 04:00 PM
