Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 07-06-2006, 11:18 AM   #1
Profile:  1968 17' Caravel
Virginia City , Nevada
lube for door hinge?
The door hinge on my 68 is groaning. What is the best lube (product name) to use? And not to use? I assume this info is elsewhere but I can't find it right now. Thanks. Edwwwwwwwwwwwwwwwww
edwmart is offline   Reply With Quote
Old 07-06-2006, 02:54 PM   #2
Steve & Susan's Avatar
Profile:  2005 28' International CCD
Willoughby , Ohio
I use a silicone lube.
Since the hinge is aluminum on aluminum, you're going to get black gunk that builds up over time on the hinge - remember this when you enter and exit - it makes a MESS of clothing!!
Steve & Susan
2005 28' CCD, 2002 Silverado-C1500, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 07-06-2006, 06:07 PM   #3
Profile:  1977 31' Sovereign
McHenry , Illinois
Silicone is really not that good a lubricant, so I use a lighter weight sewing machine oil to do the job. I have SS hinge pin and plastic thrust washer.
dwightdi is online now   Reply With Quote
Old 07-06-2006, 06:20 PM   #4
juel's Avatar
Profile:  1978 Argosy 24
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Boy this sounds too simple, but I got great results with WD=40. Of course that and duct tape is really all you need for most of life's projects.
juel is offline   Reply With Quote
Old 07-06-2006, 07:33 PM   #5
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
When I set up the trailer and get it ready to tow I have a can of WD-40, a can of Silicone, and Reese hitch ball lube on the storage comparment door. I lube as I go, I wipe down my water hose and power cord with a shop towel and Silicone every time a stow them. Keeps things clean and a lot easier to handle.
Thanks Jim
Air # 174
Jim Clark is offline   Reply With Quote
Old 07-06-2006, 09:47 PM   #6
CaddyGrn's Avatar
Profile:  1963 16' Bambi
Yreka , California
Airstream Registry
Check your rivets...
Hello,
We have a 1963 Bambi... when my husband disassembled it during restoration he discovered that our door has a steel plate on the back for support, stainless hinge, sandwiched with the aluminum skin and aluminum rivets. We nearly lost our door (almost flew off going down the interstate... ) because our rivets had corroded and just sheared off. They looked fine on the outside. So, if you haven't restored or gone so far as to disassemble your shell to see how your door is riveted... and it is groaning... along with some kind of lubricant, you might also check the integrity of your rivets. It was awful to look out the rear view mirror and see the door to our Airstream dragging on the road...
If that doesn't appear to be an issue, then use whatever you can that stops the groan and go camping!
Mrs. NorCal Bambi traveling in STardis
CaddyGrn is offline   Reply With Quote
Old 07-07-2006, 01:12 AM   #7
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
EdW,
I use a fairly new product from DuPont called Teflon Dry Lube. It is usually available in aerosol or liquid bottle from Lowes, or from a few automotive sources on the Net. It is probably the best lube I have used in the recent past.
It sprays on wet then dries quickly to a smooth, dry finish, has great staying power, is non-reactive with just about anything and also does a great job of lubricating. I currently use it on everything from squeaks and rattles to awning rails to hinges to bicycle and motorcycle chains. It does not collect dirt or dust and stays on in the rain also.
PS: I will not use WD-40 for anything except an ocassional rusted bolt, but PB Blaster works much better there anyway!!!
Lew Farber -Certified Master RV Tech (currently on Forums posting sabbatical, but lurking in the background )
WBCCI #1456 and about to resign!/VAC (assoc) #1456/ AIR # 10325
TAC# OR-1
CHARTER MEMBER: FOUR CORNERS UNIT
Old 07-07-2006, 04:01 AM   #8
Road Ruler's Avatar
Profile:  1973 23' Safari
Burlington , South Western Ontario
Images: 45
Dry Lubes are the way to go. Jig a lube also sprays on wet, soaks in, and thats it. NO BLACK RESIDUES ever!! Also great on window sliders etc.
We have 7 bikes (pedal). Before using dry lubes I was spending hours every year cleaning dirty, oily, black chains. Now the time spent is about 80% less.
Road Ruler is online now   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
How do I lube the tongue jack 63air Jacks, Stabilizers, Lifting and Leveling 4 06-29-2006 10:32 PM
window crank lube Jabba Windows & Screens 7 06-08-2006 08:22 PM
couldn't get coupler off the ball qqq Hitches 20 10-02-2003 01:00 PM
repacking the Wheel Bearings Chuck Axles 26 04-27-2003 08:59 PM
GM a/c control panel rdm Mechanics Corner - Engines, Transmission & More... 5 11-11-2002 07:30 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
