07-27-2006, 06:26 PM
1973 31' Excella 500
Morristown
, Tennessee
Lost the Only Key - Please help
I know it's stupid but I lost the only key to my newly purchased trailer. The main cabin is unlocked but can't get access to any of the small appliance doors.
Can a key be made for the door lock and then fit all of the others? The lost key fit all of the locks. Does Airstream have a master that could be copied and purchased?
Please help.
Joe
07-27-2006, 06:33 PM
1979 23' Safari
1954 29' Liner
Orange
Please help.
Joe
Joe,
A locksmith can make you a key. One did that for me when I was missing the key to the water fill door.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
07-27-2006, 06:43 PM
Morristown
, Tennessee
I appreciate the quick answer. I am sick since I just brought the trailer home last weekend and am just starting to get it in shape.
I'll try in the AM.
Joe
07-28-2006, 03:35 PM
Morristown
, Tennessee
Got the key made today by a local locksmith. It works fine in the door but have to check it on the appliance doors. Cost $10 plus tax - 7% in Florida. That won't happen again.
Joe
07-28-2006, 05:02 PM
1975 27' Overlander
fort wayne
, Indiana
keyS
hope you had more than A key made.
crowbar
p.s. been there
07-29-2006, 12:42 AM
Morristown
, Tennessee
The locksmith only made one key. It opened the main door lock but he wanted to wait until he heard that it opened the other access hatches. I tried it on the other locks and it doesn't work. It is not the right blank. I have two choices at this point. The locksmith said I could tow the trailer to him or I can figure a way to remove on of the doors and take it to him. My battery hatch does not fit properly so I will try to remove it, get the key and then reinstall properly. The headache continues.
Joe
07-29-2006, 01:42 PM
1986 25' Sovereign
Southern Middle
, Tennessee
Joe
When you get the right set of keys cut, make two extra sets. Keep one set in the glove compartment of your tow vehicle, one on a key ring in the house and one inside your trailer. This should also include a key for your hitch lock if you use one. I have gone all out to identify each ring set by attaching objects to each set as seen below.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
07-29-2006, 03:23 PM
Corona
Joe
All Airstream dealers have keys that will fit the 73 compartments. You can borrow one, and have it duplicated, or find a dealer that has them.
The key # is 1101X, for all the trailers back then.
This will work unless the previous owner, changed the code.
07-29-2006, 03:30 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
i think she needs one of your key rings andy!
john
you call them ferrets, i call them weasels.
07-29-2006, 03:37 PM
Corona
john
Key rings, or key chains?
If she calls, we certainly can solve her key problem.
