Old 02-26-2006, 05:43 AM   #1
Looking for time
jamesardis's Avatar
1971 23' Safari
midland , Michigan
look at this pic
nubie here-can anyone explain to me how this little screen door holder comes apart?--I think it must come apart so that I can re-rivit it back onto the door--tanks--jim from mich[71 safari]--the spring needs to be replaced as well
Name:	trailer screen latch.jpg
jamesardis is offline   Reply With Quote
Old 02-26-2006, 05:25 PM   #2
Looking for time
jamesardis's Avatar
1971 23' Safari
midland , Michigan
what?--nobody knows?
someone has taken this device apart Im sure of it!--are these only on the 70s trailers?-jim
Old 02-26-2006, 05:32 PM   #3
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Ok ok...
Here's what you need. The old ones do not come apart, at least mine did not.
There's a replacement kit available from Airstream.
InlandRV has it, too.
http://www.inlandrv.com/parts/18777-latch.jpg
Uwe
www.area63productions.com
Old 02-27-2006, 05:32 AM   #4
Looking for time
jamesardis's Avatar
1971 23' Safari
midland , Michigan
thanx
thank you uwe--Ive been obsessed with the mechanics of this original one! I had not checked around for a replacement til I had consulted the forum tubers and had exhausted that avenue-I appreciate you doing it uwe--tanks-jim from mich
Old 02-27-2006, 09:36 PM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Originally Posted by uwe
Ok ok...
That must be a new model because it does not look like what was on my '77 Excella or my '86 Sovereign. My Sovereign had an aluminum outside cover over the first parts shown here and the Excella parts consisted of a black rectangular base, a spring and then the outside unit just snapped into place. The parts you have displayed should seperate with a little work.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-27-2006, 10:16 PM   #6
mcneon's Avatar
Check out this link:
http://www.airforums.com/forum...eferrerid=2627
As far as I know, all of the latches that look like the one in your picture are the same. It takes a lot of force, but they will come apart!
Bob in Nashville
mcneon is offline   Reply With Quote
Old 03-22-2006, 07:06 PM   #7
Looking for time
jamesardis's Avatar
1971 23' Safari
midland , Michigan
Mystery solved
the disassembly of this latch has been discovered
they said it could not be done
before the eyes of this austere group it is reveiled
behold!
[please forgive the crummy pics
while fully retracting the latch insert knife between the two parts and lift or twist-the top will pop up and all will be reveiled!! As you can see the grooves do not run continously from one side to the other-there is a gap in the middle that allows this separation to take place--
it is with great joy that I now can reattach this wonderous little 35 year old device to my most loved safari--And andy of indland rv will not be getting 20 bucks for a new one ----------jim from mich
ID:	19681   Click image for larger version
Old 03-22-2006, 07:10 PM   #8
Looking for time
jamesardis's Avatar
1971 23' Safari
midland , Michigan
And as you can see there wasnt a spring in this latch-the PO probly had it apart and didnt re insert it-I wonder if a ballpoint pen spring will work?--jim
Old 03-22-2006, 08:37 PM   #9
Darol Ingalls's Avatar
Thanks for the education. I've tried to get those things off to replace several times and gave up. Now - how about a lesson in the radio antenna bracket. I want to remove the one on my '65 Tradewind, but it appears to be held on with machine screws with the nuts rusted on because they turn but do not loosen. There is no provision to get at the nuts from the interior. I'm tempted to cut the thick rubber gasket out to get at the screws with a hacksaw, but have not worked up the nerve. Any suggestions???
Darol Ingalls is offline   Reply With Quote
'80 Caravelle Whisperwoman1 1980 Caravelle 10 09-22-2013 07:51 PM
Anyone have a pic of the Toronado using WD? Xray Hitches, Couplers & Balls 9 12-31-2012 01:42 PM
For you pilots... Chuck On The Road... 20 09-16-2011 08:27 PM
Hello to all here is a PIC of my '68 GT Jim Clark 1965 - 1969 Globetrotter 8 08-12-2007 07:27 PM
Jacking points on '77 27' International johnmw Jacks, Stabilizers, Lifting and Leveling 13 12-13-2002 12:05 AM
