Old 10-28-2004, 10:14 PM   #1
locks for battery box and propane box
I just got my new 19' International CCD! But the battery and propane boxes have no provisions to secure them. Any ideas?
Chilao is offline   Reply With Quote
Old 10-29-2004, 07:45 AM   #2
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Battey box
I had the 22' International AS that had the same battery box on tthe A-frame. I swaged thimbles on both ends of a 1/8" piece of aircraft cable just long enough to go around the battery box and attached 2 footman's loops to the battery box itself (3/16" pop rivets with washers on the inside). I made the cable just long enough that a padlock could go through the thimbles. Aitcraft cable ius tough to cut. SOmeone could have taken the time to cut it and taken my battery, but I no longer worried about someone simply opening the battery box and walked off with the battery.
I'm sure that I posted a photo of it at some point in the distant past.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 10-29-2004, 08:00 AM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
http://www.airforums.com/forum...ead.php?t=2611
Old 10-29-2004, 04:51 PM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Since the 19' has a twist lock top door, you could replace that non locking type with a keyed locker so that you'd need a key to open it.
As for the propane, that one might require a bit of engineering....tap tap....John!
Old 10-31-2004, 11:49 AM   #5
It is very "unsafe" to ever put a lock on any cover or door for LPG bottles or tanks.
Old 10-31-2004, 11:59 AM   #6
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Chilao.
Read this:
http://www.airforums.com/forum...ry+compartment
Then buy this:
http://www.campingworld.com/browse/s...m?skunum=17109
And after that, you can say, that crazylev dude is the greatest!!! I'm votin' for him for President!!!
Seriously, though. This conversion took me all of five minutes, and I no longer have to pull the fuse for the electric jack to keep anyone from monkeying around with that. To use the jack, I just rest the wire on the terminal of the battery, and when I am done, I sort of tuck it in on the side of the battery.
Good luck.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is online now   Reply With Quote
Old 10-31-2004, 12:04 PM   #7
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
...oh, and as far as propane goes, I'm with Andy on this. In case of emergency, you want to have pretty easy access to those shut off valves.
I just take my two 30 pnd.propane tanks out and store them next to my furnace in the basement, near my canisters of amonium nitrate. Keeps 'em warm and happy.
(BTW: I am JUST KIDDING ABOUT THE LAST TWO SENTENCES!!!! Don't do that!!!)
Jonathan
Old 10-31-2004, 03:09 PM   #8
Aluminut
2004 25' Safari
. , Illinois
Originally Posted by crazylev
Exactly what I was thinkn' of.
Old 10-31-2004, 03:29 PM   #9
Images: 59
Jonathan
You should NEVER store ammonium nitrate in the basement. Any moisture will cause it to harden into a solid lump. Best to blend it with some diesel fuel and store it in a dry place, like the bedroom.
Old 10-31-2004, 03:40 PM   #10
Yeah, that's right.
You might get more bang, for your buck too.
Old 11-02-2004, 06:40 PM   #11
Thanks for all your replies!
I think I paniced before thinking. I replaced the thumb screw latch on the battery box with a locking cam latch. I realized locking the propane box was a bad idea. I ended up using a cable and a padlock to secure the bar that holds down the propane tanks. This way the tanks can be turned off but they can't be lifted out.
Old 11-02-2004, 06:56 PM   #12
Images: 59
If you want the same lock, go to Sears and buy a set of tool cabinet locks. They come in sets of three, keyed alike, for $15.
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
Refrig pressure gauge. casarodante Refrigerators 5 07-08-2002 11:04 AM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Propane and Electrical Line Protection Tamara Electrical - Systems, Generators, Batteries & Solar 7 06-27-2002 09:42 PM
