Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 10-28-2004, 10:14 PM   #1
Chilao
Profile:
locks for battery box and propane box
I just got my new 19' International CCD! But the battery and propane boxes have no provisions to secure them. Any ideas?
Chilao is offline   Reply With Quote
Old 10-29-2004, 07:45 AM   #2
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Battey box
I had the 22' International AS that had the same battery box on tthe A-frame. I swaged thimbles on both ends of a 1/8" piece of aircraft cable just long enough to go around the battery box and attached 2 footman's loops to the battery box itself (3/16" pop rivets with washers on the inside). I made the cable just long enough that a padlock could go through the thimbles. Aitcraft cable ius tough to cut. SOmeone could have taken the time to cut it and taken my battery, but I no longer worried about someone simply opening the battery box and walked off with the battery.
I'm sure that I posted a photo of it at some point in the distant past.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 10-29-2004, 08:00 AM   #3
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
http://www.airforums.com/forum...ead.php?t=2611
Old 10-29-2004, 04:51 PM   #4
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Since the 19' has a twist lock top door, you could replace that non locking type with a keyed locker so that you'd need a key to open it.
As for the propane, that one might require a bit of engineering....tap tap....John!
Old 10-31-2004, 11:49 AM   #5
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
It is very "unsafe" to ever put a lock on any cover or door for LPG bottles or tanks.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 10-31-2004, 11:59 AM   #6
crazylev
LEV ZEPPELIN
crazylev's Avatar
Profile:  2004 19' International CCD
Chicago , Illinois
Chilao.
Read this:
http://www.airforums.com/forum...ry+compartment
Then buy this:
http://www.campingworld.com/browse/s...m?skunum=17109
And after that, you can say, that crazylev dude is the greatest!!! I'm votin' for him for President!!!
Seriously, though. This conversion took me all of five minutes, and I no longer have to pull the fuse for the electric jack to keep anyone from monkeying around with that. To use the jack, I just rest the wire on the terminal of the battery, and when I am done, I sort of tuck it in on the side of the battery.
Good luck.
Jonathan
I'm out of my mind right now, but will be returning shortly......
crazylev is offline   Reply With Quote
Old 10-31-2004, 12:04 PM   #7
crazylev
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
...oh, and as far as propane goes, I'm with Andy on this. In case of emergency, you want to have pretty easy access to those shut off valves.
I just take my two 30 pnd.propane tanks out and store them next to my furnace in the basement, near my canisters of amonium nitrate. Keeps 'em warm and happy.
(BTW: I am JUST KIDDING ABOUT THE LAST TWO SENTENCES!!!! Don't do that!!!)
Jonathan
Old 10-31-2004, 03:09 PM   #8
Silvertwinkie
Aluminut
Originally Posted by crazylev
Exactly what I was thinkn' of.
Old 10-31-2004, 03:29 PM   #9
markdoane
Profile:  , Minnesota
Images: 59
Jonathan
You should NEVER store ammonium nitrate in the basement. Any moisture will cause it to harden into a solid lump. Best to blend it with some diesel fuel and store it in a dry place, like the bedroom.
Non-contributing deadbeat.
Old 10-31-2004, 03:40 PM   #10
Commercial Vendor
Yeah, that's right.
You might get more bang, for your buck too.
Inlandrv.com
800-8777311
Old 11-02-2004, 06:40 PM   #11
Chilao
Profile:
Thanks for all your replies!
I think I paniced before thinking. I replaced the thumb screw latch on the battery box with a locking cam latch. I realized locking the propane box was a bad idea. I ended up using a cable and a padlock to secure the bar that holds down the propane tanks. This way the tanks can be turned off but they can't be lifted out.
Old 11-02-2004, 06:56 PM   #12
markdoane
Images: 59
If you want the same lock, go to Sears and buy a set of tool cabinet locks. They come in sets of three, keyed alike, for $15.
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
Refrig pressure gauge. caadoptees Refrigerators 5 07-08-2002 11:04 AM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Propane and Electrical Line Protection Tamara Electrical - Systems, Generators, Batteries & Solar 7 06-27-2002 09:42 PM
