Old 08-10-2004, 07:25 PM   #1
Tinkerer's Avatar
Angry Locks & Keys
I've just acquired a 1969 Ambassador and a pocket full of keys. Problem: None of the keys fit. Good luck: The entry door is open and the rear hatch is open. The side hatches are firmly locked. What is the best and most reasonable way to approach this problem?
Tinkerer is offline   Reply With Quote
Old 08-10-2004, 08:49 PM   #2
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Try every key you can get your hands on. The locks are not unique to Airstream. You might get lucky.
The locks on the compartment doors can be drilled out and replaced.
A locksmith might help you with the entry door.
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 08-10-2004, 08:56 PM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Lube everything. The keys may be right, the locks could just be corroded. If they are x1011 locks then the new keys will fit. The locks can be gotten form a couple of sources. If they are just a round lock then CW is a good source.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-10-2004, 11:12 PM   #4
JohnG's Avatar
I would agree. Spray it down with a good lubricant then work the keys in and out. Jiggle them around to get the tumblers working. You may very well have the right keys and the tumbler locks are just sticking.
Just adding my 2˘ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-10-2004, 11:22 PM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Well, my suggestion would be to get a true-blue locksmith. I've had lots of locks rebuilt. They can do a first-rate job and provide you with new keys all around. And it really isn't very expensive!
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 08-10-2004, 11:25 PM   #6
JohnG's Avatar
Lynn
That's not a bad idea. You could go from a pocketfull of keys down to just a few. All compartment doors could be the same key, then one for the main door lock and one for a deadbolt if you have one.
John G
Old 08-11-2004, 12:37 PM   #7
Tinkerer's Avatar
Thanks folks for the tips on the keys. Of the batch of keys that I had, only one would fit into the lock. I might try the lubricant idea with that key to see if any tumbler gives way. The keys are probably the leat of my problems before I get it finished. We hauled it from NM to MO and it did pull good. I'll keep you posted as things progress. Thanks again. I appreciate your help,
Old 08-11-2004, 04:51 PM   #8
AirConditioner's Avatar
There's a couple ways to approach this: (1) The easiest way (if you can) is to access the back side of the hatches so you can and remove the locks. The lock bodies are usually removable by sliding the retaining clip off the back of the lock body, or by removing a nut. Usually there are two different hatch keys, so it shouldn't be too much work to get the locks off. Take them to you local locksmith and either replace the lock assemblies and get new keys, or have the locksmith make a set of keys to match the originals. The door lock is also easily removed and the locksmith can either replace the cylinder (it's still available) or key to the existing.
(2) If there are numbers on the lock bodies (frequently) your locksmith can cut keys to the manufacturers number. Best of lock with your project!
AirConditioner is offline   Reply With Quote
Storage Compartment Locks - 1968 Jim Clark 1965 - 1969 Globetrotter 14 11-08-2017 08:05 AM
replacing compartment locks Dave Cole Exterior Storage Compartments & Access Doors 3 08-14-2008 07:34 PM
side compartment locks & keys dogwood Exterior Storage Compartments & Access Doors 4 08-05-2004 05:20 PM
Can i get keys for access panel locks that have numbers dufrain Exterior Storage Compartments & Access Doors 3 01-16-2004 05:18 PM
keys mazda997 Doors & Locks 10 11-04-2003 12:10 AM
