Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 07-11-2006, 07:42 AM   #1
empresley's Avatar
1984 34' International
1977 Argosy 24
Central , Georgia
Locked out / How to get back in?
It is an '84 International, 34ft. I locked the door with the key and apparently the lock (not the key cylinder) has failed. No amount of key turning will free up the internal mechanism and the door remains locked tight. Is there a method to get inside without destroying hard to replace items?
Martin
Forsyth, GA
empresley is offline   Reply With Quote
Old 07-11-2006, 07:55 AM   #2
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
See if you can get in through your back cubbie....hopefully you have the same access I do under my rear bed. From there maybe you can take the lock apart from the inside screws and work at it that way.
enduroryda is offline   Reply With Quote
Old 07-11-2006, 08:18 AM   #3
AIR #8691
2006 25' Safari SS SE
Northern , Virginia
I once used a battery powered drill to drill out the lock mechanism on regular house door handle lock. Then used a small tool to rotate that locking bolt back into the door. That method might work for you. As understand it the lock broken and has to be replaced anyway. Good Luck.
JStanley is offline   Reply With Quote
Old 07-11-2006, 08:29 AM   #4
empresley's Avatar
1977 Argosy 24
Central , Georgia
Thanks for the suggestions. I found another thread under Doors & Locks that has all the information I needed.
thanks again,
mp
Old 07-11-2006, 10:35 AM   #5
Martin
Forsyth, GA
There is an easy way to enter the trailer, without touching the lock.
I "WILL NOT" post that information here, since a thief could learn from it.
Call me at 800-8777311, and I will tell you how to do it.
Takes less than one minute, and your in the trailer.
Andy Rogozinski
Inland RV Center
Corona, CA
Back from our Maiden Voyage!! cykakris Our Community 12 03-12-2008 07:35 PM
To Columbia,CA and back... Safari Tim On The Road... 9 04-18-2004 03:04 PM
"THE" Letter !!!-Zoning violations discussions airstreamcaravel Title, VIN & Registration 108 01-06-2004 07:41 PM
math wiz's: how steep a slope can I back up? Chuck Towing, Tow Vehicles & Hitches 12 05-05-2003 01:18 AM
Production Numbers on Front and Back? Guitars WBCCI Forum 5 11-24-2002 08:47 AM
