Old 11-01-2011, 06:36 PM   #1
SteveH's Avatar
Common Sense , Texas
Locked Out AGAIN!
While at a rally this last weekend, somehow the door locked behind me, ('04 model regular lock) and I swear I did not lock it. Fortunately I was able to get to a spare set of keys I had in the truck, but this door self locking thing is sort of irritating.
Anyone have a way to stop it from happening while keeping the lock functional?
Regards,
Steve
Old 11-01-2011, 06:41 PM   #2
r carl's Avatar
Lin , Ne
Andy has your answer.
http://www.airforums.com/forums/f453...out-67725.html
Old 11-02-2011, 12:58 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Leave a spare key in a secure location. I had a lockout occur after installing Andy's kit, and no longer trust it.
Old 11-02-2011, 01:08 PM   #4
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Ditto
Our keys are never in the Airstream by themselves. If we go out, they go out. We nag each other to ensure this.
There is also a spare, pair in a hidden key-box outside.
Sorry for the anguish these events cause.
Hope this helps.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 11-02-2011, 01:13 PM   #5
SteveH's Avatar
Hope this helps.
Yes, this is our rule also, except this was the Halloween Rally, and we were in our goofy consumes with no pockets, and that's when it happened.
Regards,
Steve
Old 11-02-2011, 02:07 PM   #6
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Oh, the Humanity...
Locked out of your Airstream in a goofy costume to boot.
Ken L
1966 Tradewind 24
Old 11-02-2011, 02:18 PM   #7
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
We don't believe the "goofy" part without pics.
Old 11-02-2011, 02:25 PM   #8
There are "FREE" lock out kits available.
Ask those that have installed them.
Old 11-02-2011, 02:28 PM   #9
SteveH's Avatar
OK, But I did warn you!
Name:	Goffy Halloween.jpg
Regards,
Steve
Old 11-02-2011, 02:35 PM   #10
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Thanks. Plenty of space in all that hair to hang keys, bones, feathers, extra bbq sauce packets, whatnot.
Old 11-02-2011, 02:36 PM   #11
1969 27' Overlander
No pockets...
Shortly after inventing fire, Mooog invents pockets, after repeatedly locking himself out of his cave.
edglenn is offline   Reply With Quote
Old 11-02-2011, 02:54 PM   #12
Denis4x4's Avatar
Durango , Colorado
Since it's against the law (and common sense) to lock the propane tank compartment, I drilled out a side compartment key to fit on the hold down threaded rod. It's not visible at first glance. Could also fit on the battery hold down. That key opens a side compartment that has a door key. You only have to be locked out once to figure out a solution!
Denis4x4 is offline   Reply With Quote
Old 11-02-2011, 03:43 PM   #13
SteveH's Avatar
Oh sure, it's funny now! :-)
OK, took the lock apart, and figured out what the problem is (the spring on the locking lever is too soft), allowing the locking lever to move too freely. But, that spring is too difficult to get out, let alone find a stronger version. However, I did figure out a solution to the locking lever moving too freely, and made a damper, so to speak, that will keep the lock from locking too freely.
It's nothing more than a plastic washer, 1/2" X 5/16" X .018" inserted under the locking lever. The lock still works normally, but the lever is not as free to move, so hopefully this will prevent the thing from locking itself when the door is closed.
Pictures to follow.
Regards,
Steve
Old 11-02-2011, 04:12 PM   #14
SteveH's Avatar
The first picture is the lock our trailer has. The second indicates where the washer is placed under the locking lever.
Name:	Halloween Rally 2011 018.JPG
ID:	144437   Click image for larger version
Name:	Halloween Rally 2011 017.JPG
Regards,
Steve
'73 Door Handle went to crap funkill Doors & Locks 44 10-11-2015 02:55 PM
Locked out Ben4762 Doors & Locks 4 07-25-2011 05:28 PM
Locked out! tcrum Doors & Locks 4 06-06-2011 08:51 AM
Help! Locked Out '79 Arogsy nick6930 Doors & Locks 10 07-25-2010 08:16 PM
Looking for honest opinions on locked up trailer brakes. Cogen Brakes & Brake Controllers 15 06-02-2008 01:25 PM
