Old 04-03-2010, 04:35 AM   #1
1999 25' Safari
WINDSOR , ON
Locked out
i have a 1999 safari as, got home from a trip and the door will only open approx. 1/8 in. there is a deadbolt which you simply push from the inside to lock, i think as i was travelling on rough roads that it somehow moved and locked the door. can you knock the pins out of the hinges and remove the door, you can see the top of the pin but the bottom looks like it was "welded" in?? any other suggestions would be appreciated.
garryg is offline   Reply With Quote
Old 04-03-2010, 05:31 AM   #2
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
The front window is a good bet!
'77 Sovereign Intl 31' CB
Old 04-03-2010, 06:33 AM   #3
r carl's Avatar
Lin , Ne
Will a putty knife pry it back?
Old 04-03-2010, 06:40 AM   #4
Kristi Foster's Avatar
Jonesboro , Georgia
Images: 33
Locked Out
We were locked out this past Fall with our dog locked inside! Our 8 year old granddaughter climbed through the outside storage access door and through the cabinet opening under one of the beds. She wasn't afraid of our 80 lb. dog ,which was a plus, and was able to figure out the screen door latch and the main door lock handle from the inside. She saved the day!
Kristi Foster is offline   Reply With Quote
Old 04-03-2010, 06:48 AM   #5
1999 25' Safari
WINDSOR , ON
everything ok
thank you for suggestions. this as has the windows that only open about 5 in. at the bottom, i was able to pry window enough to insert long scewdriver and turn knob to open window. only had to ruin screen. whew!!!
Old 04-03-2010, 09:54 AM   #6
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
My previous owner made a modification that prevents the bolt from latching itself. If you picture a bolt-action rifle, he took a dremel tool and cut out a notch for the bolt lever to rest in when the dead bolt is not in use. Easy and perfect prevention.
Glad your lock-out was so easily fixed.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 04-03-2010, 10:00 AM   #7
2010 27' FB Classic
N/A , Texas
Pat, If you get the time, please post a picture of the modification. I would like to see it. I could give you my email address, if that would make it easier.
Old 04-03-2010, 11:12 AM   #8
We have a "FREE" lock out kit.
Send us a "SASE" with 2 stamps on it, and we will send the lock out kit to you.
Hundreds of owners have already done so.
Old 04-04-2010, 12:06 PM   #9
Ready-to-Travel
pmclemore's Avatar
Here it is, Bluto. Andy's solution is likely more elegant, and may solve the accidental locking of the door lock. But this is an easy way to solve the deadbolt.
As you can see, there is a cut-out where the dead bolt lever can sit whenever you are not engaging it.
Pat
ID:	99403   Click image for larger version
AIR 3987
TAC VA-2
WBCCI 4596
Old 04-05-2010, 05:13 AM   #10
2010 27' FB Classic
N/A , Texas
Thanks Pat, that looks good and simple too!
Locked Out finn2020 Doors & Locks 14 05-15-2012 11:44 AM
locked out STERELLIE Doors & Locks 3 05-21-2009 06:15 PM
Locked out 66 Safari CAPT100J Member Introductions 3 07-26-2008 08:21 AM
Locked Out!!!! starr Doors & Locks 9 04-10-2008 12:23 PM
I'm Locked out!!! larry smith Doors & Locks 3 03-01-2005 05:52 AM
