Old 04-08-2008, 08:58 AM   #1
1966 26' Overlander
Weaverville , North Carolina
Locked Out!!!!
My daughter and I were preparing to spend our first night in our 1966 Overlander last night....
But we couldn't get in!
I had just opened the entry door twice before that day, but now it's stuck. The key goes in, the key turns, the knob turns, the bolt turns, but the door just won't open. I was pretty disappointed. Not to worry, though, we have a conversion van with a comfy bed in the back, so we got a good night's sleep.
Any suggestions? It looks as though someone might have had this problem already with this unit. It's got a little tiny tear on the edge of the door like it was popped with a knife or a screwdriver. The door is NOT sprung. I realize that I am probably going to have to replace the door, the lock, or both, but for now I just want to get into my house!!!
Starr
(This is going to make a great blog entry...)
An Inherently Sovereign Being, Following Her Highest Excitement
Check out the Travelblogue! http://sadhanastarr.squarespace.com
starr is offline   Reply With Quote
Old 04-08-2008, 09:03 AM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
If you have the compartment keys, you (or a small child) can probably get in through one of those doors and open it from the inside. Then troubleshoot the lock...and fix/replace as needed. The only concern is it may be one of those that is no longer available...can you post any pictures of it or is your camera in the trailer?
Good luck...let us know how it works out.
Shari
Old 04-08-2008, 09:03 AM   #3
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
Send a message via Yahoo to Tin Diesel
We've occasionally had a problem with a stuck door, where everything else seems to be OK, as you described (lock, bolt, etc).
I've found that the frame of the unit can twist a bit. Try changing the pressure from your stabilizers (are they down?). Perhaps a temperature change (overnight?) caused a minor expansion or contraction in the frame, slightly pinching the door. Maybe you set it up in the shade, and the sun caused a change.
I would say try pulling harder, but I'm sure you've tried that.
Good luck.
Hey, its the only way to be sure!
Tin Diesel is offline   Reply With Quote
Old 04-08-2008, 09:05 AM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Hello Starr. We don't want to post info on how to enter a locked Airstream with the least damage -- not like a crook would bother. But I would suggest calling Andy at Inland RV -- 951-734-8130. He will give out this info only over the phone after making some assessment of who he's talking to. Please use my screen name as a reference if you wish. Good luck!
5 meter Langford Nahanni
Old 04-09-2008, 09:15 PM   #5
1966 26' Overlander
Thanks everyone for the great advice! I tried looking for hatches and crannies to climb through, but found that they were all too small for me to fit through- only big enough for a six year old. And I didn't have any of those handy (my daughter's only two), so.....
I headed on down to North Dallas RV. I HIGHLY recommend these guys. They specialize in Airstreams, and give excellent service. The staff was incredibly friendly and helpful. We discovered that the window right next to the door was plexiglass, and we were able to bend it out and reach in and open the door from the inside. Upon examination, it became clear that the tumbler had broken inside the lock. Then they put a whole shiny new doorknob on, and gave me a thorough tour of how my Airstream works, and how to hook it up.
Thank God for plexiglass! (My daughter managed to lock herself in the Airstream today when I went five feet away to get my toothbrush out of the van. I simply bent that plexiglass out again and opened the door through the window!)
-Starr
Old 04-10-2008, 05:51 AM   #6
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Starr....be sure to seal around the new door knob with some good sealant so that you don't get any leaks at the seam that would compromise your new lock.
Congratulations on your new Airstream! They are a lot of fun!!
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 04-10-2008, 07:02 AM   #7
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Starr
Call Andy at Inland RV's in California IF its a lock problem Andy knows how to get U in ,he will only tell U on the phone. I think they even have a 800 number.
Good Luck
Roger
Mikethefixit is offline   Reply With Quote
Old 04-10-2008, 08:28 AM   #8
phoenix491's Avatar
1965 20' Globetrotter
Keller , Texas
I'm glad you ran across North Dallas RV -- they are top-notch, as you said. Friendly, knowledgable and very helpful ... they'll be getting my business for years to come.
As for being locked out, I feel your pain. We were camping in Oklahoma a few weeks ago when my wife tracked me down on the trout stream I was fishing to inform me that she had somehow locked the keys in the trailer. Our ONLY set of keys, mind you. (This has since been remedied.) After 30 minutes of shaking, rattling and prying with my Leatherman, I admitted defeat. So, I went back up to the Ranger's office and asked them to call a locksmith for me. One hour and $60 later (I would have paid twice that without a blink), we were back inside, with a re-built doorknob (an interior piece had been installed backwards, causing problems). The locksmith said he spends quite a bit of time out at the campsite thanks to lost keys, broken latches, etc. ... made me think I need to learn a new trade!
phoenix491 is offline   Reply With Quote
Old 04-10-2008, 09:49 AM   #9
ScottW's Avatar
Hernando , Mississippi
I make it a habit of keeping a spare set of trailer keys in the pickup (which also has keypad entry). Yes, I know the keypad won't work if the pickup battery (both of them) dies, so I also have a spare truck key hidden. Plan for the worst, hope for the best.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 04-10-2008, 12:23 PM   #10
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Lock out
It's a good idea to change out the entry door cylinders to new.
I have not yet followed my own advice, but I have put on a hasp with built in keyed lock made by Stanley. I use this as my primary lock and don't mess with the entry door lock. If you do this make sure to put it down low so it clears the trailer skin when the door is fully open.
Lumatic is online now   Reply With Quote
Help - MH Brakes Locked Up! swebster Mechanics Corner - Engines, Transmission & More... 99 07-31-2017 05:22 PM
Locked Out finn2020 Doors & Locks 14 05-15-2012 11:44 AM
Locked out of '71 Safari Larry71 Doors & Locks 11 06-13-2005 09:35 AM
I'm Locked out!!! larry smith Doors & Locks 3 03-01-2005 05:52 AM
Locked in...Yikes! AnnZ3 Doors & Locks 14 08-26-2004 08:02 PM
