Old 08-06-2014, 07:57 AM   #1
1963 19' Globetrotter
1948 22' Liner
Fort Worth , Texas
Locked out! 1951 Silver Streak Clipper
After hauling 842 miles, door now won't operate. Lock cylinder turns as normal (lock/unlock, 180 degrees), but does not help. Handle is restricted to about 5 degrees. I can see the the handle on the inside moving marginally in unison with the exterior.
I tried:
-every possible intermediate lock cylinder position
-pulling, tugging, lifting, pushing while turning
-removing the screws in the baseplate---only allowed the plate to rotate; does not slide over the exterior handle's barrel so did not provide any additional access
-spraying WD40 profusely
Any other suggestions?
Can anyone identify the handle make/model?
balance94 is offline   Reply With Quote
Old 08-06-2014, 08:25 AM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Call a locksmith
BambiTex is offline   Reply With Quote
Old 08-06-2014, 08:53 AM   #3
1948 22' Liner
Fort Worth , Texas
Very helpful. Thank you.
Silver Streak Clipper 4-204 dudefromdixie Vintage Kin 17 05-31-2010 02:40 PM
