Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 05-21-2011, 06:24 PM   #1
1972 31' Sovereign
princeton , New Jersey
Lock problem '72 sovereign
Can't open exterior door, which is locked and key will not turn in lock. Had lock repaired once before and it worked for a while. How do I get lock off so I can take it to someone for possible repair? if I need a new lock, any ideas about sources and prices. Thx
kayaker410 is offline   Reply With Quote
Old 05-21-2011, 06:33 PM   #2
x
XXXX , XXXX
Contact Andy at Inland RV. He knows how to gain access to your trailer. You will need to call him on the phone because of security reasons he won't publish that information here on the forums.
Inland RV Center - The Nations Leading Expert in Airstream Innovations
wasagachris is offline   Reply With Quote
Old 05-21-2011, 10:20 PM   #3
Dan@LED4RV's Avatar
Denton , North Carolina
repair yourself
here is a how-to on repairing yourself.
Airstream Lock 1970-77
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 05-22-2011, 07:09 AM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Removal
There are 4 screws that hold the lock assembly in the door. 3 on the inside of the door and one one the edge near the bolt. There is a larger screw that holds the inside handle to the shaft that must be removed along with the handle. You will also need to remove the rivets from the lower portion of the upper skin on the inside of the door in order for the shaft for the inside handle to clear as you remove the lock assembly from the outside.
I have had mine out on a number of occasions to make various repairs. If you need help with repairs I may be able to help.
A used lock is $300.00+, if you can find one; a new one is close to $600.00.
sovereign
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
Door lock issues carlvs Doors & Locks 4 05-09-2011 07:57 AM
Lock trouble on 1961 AS Ambassador... help please. 61Ambassador Doors & Locks 13 04-21-2011 02:06 PM
Xena Lock With Alarm For Hitch Coupler wjk Hitches, Couplers & Balls 8 04-13-2011 06:27 AM
Modifying a Fastec door lock jeffkraft200 Windows, Doors, Locks & Vents 12 03-26-2011 03:02 PM
