Old 07-21-2005, 10:05 PM   #1
1975 27' Overlander
Santa Fe , Texas
lock on water door
I just bought a 74 27' Land Yacht an did not get any keys with it. I was able to have a locksmith key all but the water door. Any ideas or suggestions would be appreciated. Thanks
David Kinsey
DKinsey is offline   Reply With Quote
Old 07-21-2005, 10:28 PM   #2
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
My locksmith keyed mine.
I might suggest another locksmith? Mine used a DECO key blank #1...that might be a starting point.
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 07-22-2005, 01:32 AM   #3
desi arnaz's Avatar
a 1/4 inch drill bit will do the job....
desi arnaz is offline   Reply With Quote
Old 07-22-2005, 03:57 AM   #4
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
SOB Key
David Kinsey
Oddly enough, a key from a storage access door from a 2002 Coachman (SOB) fir mine... Worth a try before destroying what is there.....
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 07-22-2005, 05:46 AM   #5
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Common key
I have never seen any key for any water door that was not the same as any other. (unless of course it has been changed by a PO). Every Key to my TT or MH was exactly the same.
Hell, I may even have an extra one some where.
Point is that the key is common. I bet you can buy one at a camping supply store.
Smily
smily is offline   Reply With Quote
Old 07-22-2005, 06:35 PM   #6
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, David,
Try going by an old, established RV dealer and ask in the service department. They're likely to have a huge keyring with a bunch of keys on it that some mechanic will methodically try one-by-one and then make you a copy of the one that fits.
Young's RV in Toledo found me a key for my battery doors that way - cost was $1.65 for the key. Their service was above and beyond on a cold February day, and I appreciated it greatly.
Lamar
SafeHarbor is offline   Reply With Quote
Old 07-22-2005, 06:49 PM   #7
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
Rivet Smily's got it right!
The generic key for the generic water door lock is pictured.
Many years of Airstreams and a great deal of SOB's have this type.
A good locksmith will have the blank in stock & it doesn't even have to be cut. You could probably call around and ask for the DECO 1.
SEE: http://www.airforums.com/forum...ad.php?t=16754
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 07-30-2005, 09:08 AM   #8
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
no go on my '72
hi- the DECO 1 didn't work on my '72 OL, after finally finding one. It is shaped pretty much entirely wrong. But thanks anyway, worth a try!
tphan is offline   Reply With Quote
Old 07-30-2005, 09:30 AM   #9
1975 27' Overlander
Santa Fe , Texas
My lock is double-sided, locksmith did try from a band of 250 keys.
David Kinsey
Old 07-30-2005, 10:14 AM   #10
Road Ruler's Avatar
Images: 38
Our 1973 Safari water door key is double sided as well and is the only double sided key on the whole trailer. Our local Airstream dealer had a key in stock that fit.
Old 07-30-2005, 06:59 PM   #11
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
yes, mine looks like a double-sided thing too- If anybody would care to bother with making a copy for me to try, for my '72 OL, I'd be grateful beyond comprehension. You can e-mail me at tphansennw@hotmail.com thanks!
Old 08-17-2005, 08:02 PM   #12
w5wi's Avatar
1976 25' Caravanner
1977 31' Sovereign
Richland , Missouri
I was checking keys and locks on my 1977 31' Sovereign and didn't have all the keys. I took the key ring from my 1976 25' Caravanner and found that the keys for the storage boxes and water door all fit the Sovereign as well. The only key I had to have made was for my battery boxes.
dale
w5wi is offline   Reply With Quote
310 door lock parts joepospisil General Motorhome Topics 8 10-02-2012 11:14 AM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
water seeping in compartment door Mike Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 10-23-2002 12:14 PM
Door Lock replacement? 3Ms75Argosy Doors & Locks 2 08-15-2002 11:12 PM
Need spring load clips for water heater door 68 GT. Jim Clark Water Heaters, Filters & Pumps 4 05-09-2002 07:39 AM
