Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 10-19-2017, 02:47 PM   #1
2007 27' Classic FB
Clearwater , Florida
Lock instructions?
I want to install a new door lock on a 2007 27FB Classic. I have the parts but have not been successful at getting the mechanism to work when the exterior part of the lock is connected to the pin on the latch and the parts are installed on the door. There is not enough movement to work. Anyone know of a how to video and written instructions on installing a door lock?
Thanks.
bross is offline   Reply With Quote
Old 11-03-2017, 03:16 PM   #2
2007 27' Classic FB
Problem solved.
I learned that the door lock is different for a right hinged door and a left hinged door. Once I had the correct parts, it was easy to install.
Alcoa Gutter seal Instructions 59toaster Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 08-16-2012 10:12 AM
Suburban Furnace instructions overlander63 Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-03-2003 09:26 PM
THE BOOK--instructions from Airstream Kistler Our Community 4 07-26-2003 05:43 PM
Instructions on using Velcro to attach homemade curtains tiniree Upholstery, Blinds, Walls & Interior Finishes 3 04-30-2003 10:49 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
