Old 12-10-2008, 03:38 PM   #1
ScottW's Avatar
Hernando , Mississippi
lite up the Lucite
I have a really nice lucite assist handle on our 07 Classic. Is there an EASY way to illuminate one end of the handle so it 'glows' when lit. I think it could be wired to small step light just below it, so both work on the same switch.
Thanks.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 12-10-2008, 04:15 PM   #2
Kevin245's Avatar
Scott,
You would most likely need to illuminate it through the end cut of the rod. So the first thing I would do is remove the handle and try the light source to see if it gives you the desired effect.
I assume that it is a folding type handle. I would cut a hole (YIKES) in the skin that aligned with the end of the handle when it is swung out in the locked position. Then install the light source into the skin and seal the opening.
William C. Swinney
Old 12-10-2008, 05:03 PM   #3
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Im thinking "LED" would be the way to go... Non heat and lots of light and low pull off the battery!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 12-10-2008, 05:33 PM   #4
vinstream's Avatar
http://www.airforums.com/forums/f318...ale-46851.html
here's a link that might help!
www.VINSTREAM.com
WBCCI # 1962
Old 12-10-2008, 06:41 PM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Lucite needs to be lit from a cut edge or end. FWIW I have Lucite (or something similar in the grab handles on my big truck. They have a bulb on each end mounted in the brackets. IIRC they are something like a 98 bulb in a socket. Biggest problem has been corrosion in the socket. They are the blurry things on the side of my truck
Aaron
WBCCI #XXXX AIR #2495
Pell lite kbw0221 Lights - Interior & Exterior 7 10-16-2010 06:14 PM
Thin-Lite replacement lens ghatfield Lights - Interior & Exterior 2 08-14-2007 01:29 PM
moho head lite switch Poprivet Classic Motorhomes 4 11-07-2006 01:48 AM
sealand lite problems emanon25 Sinks, Showers & Toilets 12 08-31-2004 01:43 AM
Thin Lite Install Pick Lights - Interior & Exterior 8 07-27-2003 12:45 PM
