Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 10-04-2009, 04:35 PM   #1
Profile:  1979 30' Argosy
saint augustine , Florida
latch queries
ok.
first latch is outside, the one that holds the entry door open to the outside. it works but is very loose. it is riveted. any suggestions on tightening this latch so that a good strong wind wont grab that door and slam it shut and scare the living &@#$^ out of me ?
second latch concerns numerous latches on the swing up doors inside. they also work but i can tell they are getting worn out. any ideas on where i can get replacements.
i'm including photos of both latches in question
ID:	88202   Click image for larger version
happypill is offline   Reply With Quote
Old 10-04-2009, 04:45 PM   #2
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Originally Posted by happypill View Post
ok.
The spring inside is broken like mine was. Drill out the pop rivets and take your broken spring to a hardware store for a replacement. Most hardware stores will have an assortment of springs. Remember that the black bolt still needs room to move, so resist the temptation to buy one that is so long that it will coil bind with insufficient travel. You're probably wondering how I know this. Put everything back on with 4 new pop rivets and you are done. Easy!
Now you will have to get used to the door latching open every time it hits the latch instead of you having to manually latch the door. Well worth it, though.
Sorry, no advice on the cabinet latches. Check the usual suspects, Inland RV, Out-of-Doors Mart, Vintage Trailer Supply, etc...
Vaughan
A sixth sense (I lack the other five) tells me that I am in serious difficulties. Oscar Levant
vswingfield is online now   Reply With Quote
Old 10-04-2009, 04:47 PM   #3
Profile:  1986 31' Sovereign
Miami , Florida
The outdoor latch is simple -- drill out the 4 pop rivets, insert new "guts", pop rivet back on.
The guts can be had in a kit from any dealer, about $5 or:
Outside Main Door Hold back 380291 [380291] - $5.95 : ODMRV , Out-of-Doors Mart
Can't help you with the inside latches as they are different from mine.
mike
Old 10-04-2009, 04:50 PM   #4
1967 24' Tradewind
Images: 32
mike
Simulations posts. Good source from mike. However, judging from your photo you probably don't need all the guts, just a spring. Mine looked exactly like yours and only required a spring replacement.
Vaughan
Old 10-04-2009, 08:21 PM   #5
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
These might work as a replacement for the lift/latches.
Grand Rapids RV-H271 CABINET DOOR SUPPORT By RV DESIGNER
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 10-04-2009, 08:41 PM   #6
Commercial Vendor
Profile:  Corona , California
ok.
The entrance door holdback metal housing and the plastic holdback with the spring, is available from dealers throughout the country.
The spring however, can probably be obtained from a hardware store.
Take the holdback apart, to obtain the spring.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Novice interested in living full time in an Airstream: a few queries snog Full-Timing 29 12-08-2008 10:56 AM
hitch queries trevelyan Hitches 2 07-28-2006 08:59 AM
Door latch for 75 rebel beck Doors & Locks 1 01-07-2006 07:30 PM
door latch grball8388 Doors & Locks 1 04-20-2005 01:51 PM
