Old 03-12-2017, 08:45 PM   #1
1976 Argosy 24
Panama City Beach , Florida
KT Lock vertical shaft/locking pin problem
I have a 1976 24ft rear-door Argosy. The PO did quite the number on it, so pretty much everything on it is having to be repaired.
The issue that I'm currently up against is our KT door lock. The exterior portion is in decent shape, but the interior handle and locking pin were missing. I've ordered replacement parts for those, as well as a new key mechanism.
I took it all apart today and lubricated everything. I got the new key mechanism installed, correctly I hope. But the vertical locking shaft seems to be jammed. From what I can understand, it's supposed to move up and down to engage the lock. I sprayed it liberally with WD40, but it hasn't budged. I tried lightly tapping it with a screwdriver and hammer, but I didn't want to warp anything.
The other issue I'm having is that it seems like the locking pin doesn't seem to fit into the hole. It's like it's slightly larger than the hole. I took a small drill bit to see if anything was broken off down in there, but that didn't seem to make a difference.
Any help would be great!
Katie
kwinton80 is offline   Reply With Quote
Old 03-12-2017, 09:48 PM   #2
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
The KT locks are made of pretty cheap material, so don't force anything or you'll end up with a useless $$$$ pile of stuff. The good news is they are pretty simple locks.
Photos would help.
DryFly is offline   Reply With Quote
Deadbolt Lock - will not lock due to pin strike point PSU1981 Doors & Locks 17 09-20-2019 09:35 AM
Best locking receiver pin recommendations? crampshaw Towing, Tow Vehicles & Hitches 7 02-04-2015 09:58 AM
Interior locking shaft for KT lock, which one? MikeAir Doors & Locks 12 07-17-2014 04:30 PM
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 11:19 AM
'72 trailer 7 pin vs '99 truck 7 pin wiring? Hawkeye5 Lights - Interior & Exterior 4 08-02-2008 02:34 PM
