Old 01-11-2020, 08:50 PM   #1
Dripping springs , Texas
KT Lock for 1975 Airstream Overlander
Hi there - I recently purchased a 1975 Airstream Overlander and the exterior door lock has stopped working - I'm locked out!
I spoke to a locksmith who said they might be able to get me in but they cannot guarantee they won't destroy the lock.
I'm wary about going that route because it appears the KT Lock 1970 - 1977 was once available (just the cylinder / tumbler OR the whole locking mechanism) on Vintage Trailer Supply, Inland RV, High Sky RV Parts and Out of Doors Mart....however, they all seem to be "out of stock" which makes me think they may not be manufactured anymore.
Does anyone know if those parts are still available anywhere?
Or have any suggestions as to how I might want to proceed?
Jpmike23 is offline   Reply With Quote
Old 01-12-2020, 11:42 AM   #2
1972 25' Tradewind
1976 31' Excella 500
Denver , Colorado
Does the *lever* on your door still work (pull open)? I am embarrassed to admit that a couple years ago I thought I was locked out of my trailer for a full week before I realized I could push in on the door, *then* pull the handle to get it open. Years of wear and vibration had worn a groove in the steel latch, and that would "lock" the handle unless you pushed it in to release it.
Thought it might be worth checking.
Otherwise, yes, that lock has become a difficult part to source, and as such, they sometimes go for up to $1,000 on eBay (crazy, I know). Its often cheaper to buy a whole door rather than just the lock!
kidjedi is offline   Reply With Quote
Old 01-13-2020, 08:15 AM   #3
Thanks for the response and suggestion.
I just gave that a try and unfortunately, no luck.
Old 01-13-2020, 09:23 AM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Are any of your hatches or storage compartments open? If they are keyed the same as your entry door, then you ought to be able to take them into the locksmith, and they should be able to produce a key without too much trouble. Similarly, I would think that any locksmith worth the title would be able to pick the lock without destroying it.
Then again, destroying it might be what you need to do to encourage you to throw the piece of junk away and replace it with something more modern and reliable. Granted, there are no simple, plug-and-play options, but you will end up with a much better, more replaceable lock.
good luck!
Old 01-14-2020, 07:34 AM   #5
Thanks for the response and suggestion. I've tried the other keys - unfortunately they don't work.
I may end up going the locksmith route. Ideally, I want to keep the lock assembly itself intact even if it ends up not functional as a locking mechanism.
I think I'm going to have a deadbolt installed lower down on the door and then just use the original assembly to open / close / latch the door.
I'll definitely post an update with the results of this ordeal!
Old 01-14-2020, 01:22 PM   #6
1972 25' Tradewind
Denver , Colorado
Here is a post I wrote when my KT failed (broke off in my hand at 11pm in sub-zero temps). It may contain some other useful information when deciding how to solve your issue.
http://beahmstream.com/1972-airstrea...lock-vts-1318/
25' 1972 Airstream Trade Wind Land Yacht
2006 Jeep Liberty CRD (diesel)
http://BeahmStream.com
Old 01-14-2020, 01:37 PM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I can tell you how to get in through a window, if you are willing to sacrifice a screen. Send me a PM.
Old 01-14-2020, 02:03 PM   #8
1972 23' Safari
Phoenix , Arizona
Same thing happened to me. I took the lock out and disassembled it then welded the latch lever where it had broke. It seems to be a week spot in the design. BTW I used a hanger wire to get in through the window nest to the lock.
Lensman is offline   Reply With Quote
Old 01-14-2020, 03:35 PM   #9
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I replaced the KT with a newer style on my cast door frame 71. Major mods to the door frame and new inner and outer skins.
Old 01-18-2020, 05:32 PM   #10
The door is open! It took a putty knife and someone who knows more about Airstreams than me. Definitely not a "high security" lock.
The original KT Lock is non-functional. Something broke internally.
Now I'm deciding between trying to get the KT Lock rebuilt and use it OR get the update kit from Inland RV for a modern lock.
I'm also considering installing a deadbolt lower down on the door with the striker going from the body into the door (not the door into the body).
Old 01-18-2020, 05:52 PM   #11
Can of beans's Avatar
1972 31' Sovereign
Silverton , Oregon
When my KT lock quit working, it was just the roll pin that the exterior lever grabs on the latch shaft, it had worn through, I punched it out and put a new 1/8" by 1/2" roll pin and I was back in business.
the interior handle uses a separate roll pin to actuate the latch, that one was fine. although as I see on the forums here, they fail in many different ways
"Daddy when's the trailer going to be finished?"
Can of beans is offline   Reply With Quote
Old 01-18-2020, 08:15 PM   #12
Aerowood's Avatar
Arvada , Colorado
The latch I used had a built in dead bolt and the stock striker plate was utilized. Its all outlined in my 71 GT full Monte thread below.
Updated keyless entry lock BAUER LOCK sc17842 Doors & Locks 6 03-22-2016 10:53 PM
1975 Airstream Overlander :: 1975 Airstream Overlander drewlean Airstream Registry Discussions 0 01-02-2014 03:14 AM
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 11:19 AM
1975 Overlander Door Lock Ultradog 1974 - 1977 Overlander 4 08-14-2012 05:00 PM
My 1975 Overlander lock won't open, it just keeps turning LucyPepper Doors & Locks 2 06-22-2009 07:36 PM
