Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 08-29-2005, 12:42 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
KT Lock dis/ re- assembly
I have 2 KT locks that I need to make into one. The first is a complete lock with a broken latch flange on the lock housing body, with key, from my 71 Trade Wind. The second is a good body and latch with no mechanism other than the tumblers, and no key, from a 70's Argosy.
I am looking for any advice on disassembly and reassembly so that hopefully I end up with one complete working lock.
Marshall
Old 04-16-2014, 08:04 PM   #2
1971 23' Safari
Bedford , Texas
Not but if you know where I can get a KT lock for my 71 Safari Let me know.
chronoboat is offline   Reply With Quote
Old 04-17-2014, 04:19 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
They are still available... sit down before you click the link!
Aaron
WBCCI #XXXX AIR #2495
Old 04-17-2014, 04:21 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Marshall
Here is an exploded view of the lock.
Aaron
Old 04-22-2014, 12:45 PM   #5
Parts stocking dealer usually have the KT in stock.
However, it's not uncommon to have them on back order as Airstream only makes a very few at a time.
KT locks, within reason, can be repaired by someone that has experience with that lock, and of course the proper parts as well.
Repairs are not cheap, but they are cheaper than a new KT lock.
All the parts are available, except the lock casting itself.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-30-2014, 03:25 PM   #6
1972 27' Overlander
Norman , Oklahoma
Any idea who might rebuild a KT lock assembly?
The return spring on the handle on my broke and the handle flaps all the time. I took it apart but the spring pins are corroded into the shaft and my wife is pressing me to go traveling the end of June.
rokjok is offline   Reply With Quote
310 door lock parts joepospisil General Motorhome Topics 8 10-02-2012 11:14 AM
That @#*# Lock niftypkg Doors & Locks 16 11-20-2005 02:28 PM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
Idler arm support assembly PeterH-350LE Mechanics Corner - Engines, Transmission & More... 0 09-11-2002 08:53 PM
Door Lock replacement? 3Ms75Argosy Doors & Locks 2 08-15-2002 11:12 PM
