04-24-2017, 08:54 AM
1973 Argosy 28
Flora
, Mississippi
KT Lock conversion kit
Hey guys, first post ever here. My girlfriend picked up a 73 Argosy 28' a few months back and we are going to refinish and use for fun and work. The issue is, the guy we bought it from seems to have broken the two most expensive parts, the large front window and the door lock. The door lock is actually missing.
Heres my question, Im pretty handy, and have been weighing replacing the KT lock vs converting it and I think conversion is what will be happening, but I cant find anywhere, what I actually need to get. Could someone provide some links?
04-24-2017, 09:33 AM
1993 34' Excella
Estancia
, New Mexico
Inland RV in Ca has both the original KT replacement $$$ and a more reasonable conversion kit (which requires some modification to the door).
They can also help with the window. If it is the middle flat window a local glass shop should be able to handle it. Some folks have used Lexan for the wrap around window.
04-24-2017, 11:28 AM
Alamo Heights
VTS sells the full reproduction KT lockset for about $150 less than Inland.
David
Zero Gravitas 2017 Flying Cloud 26U | WBCCI# 15566
04-24-2017, 03:10 PM
1973 21' Globetrotter
Houston
Or, if you don't mind doing a little fabrication, you can buy the latch assembly that is sold in those conversion kits for about $35 on Amazon or at your local RV parts place, and then make your own patch to cover the oversized hole.
good luck!
04-25-2017, 07:24 AM
1973 Argosy 28
Flora
, Mississippi
Thanks guys, after looking last night, It looks like someone has tried to fab some sort of piece in there to cover the holes, so I may have to do a bit of fabricating myself. Waiting on a service manual to see what exactly is up.
08-22-2018, 11:47 AM
Kelowna
, British Columbia
Anyone find https://inlandrv.com/product/tri-mark-lock-78-91/ at a supplier other than InlandRV? I see the trimark lock in many different models at different suppliers, but nothing with a similar chrome finish.
I've tried to order from those guys and I can't seem to get any response from them.
08-22-2018, 10:42 PM
1976 29' Ambassador
Dallas
TRIMARK 60251CHR Chrome Door Lock https://www.amazon.com/dp/B007HRJILG..._6QJFBbF7T2G52
12-01-2018, 02:15 PM
1971 31' Sovereign
Swannanoa
, North Carolina
Did you have any success with the kt lock conversion? Pictures?
05-27-2020, 11:47 AM
@steadystreamincashios
1968 28' Ambassador
1964 26' Overlander
1976 Argosy 26
Heber Springs
, Arkansas
I see the kit is not listed for sale on InlandRV anymore, but does anyone know if that same lock can be purchased on Amazon or somewhere else? I notice it has a longer slide which is obviously needed. The patch I can easily make. Thanks.
05-27-2020, 12:09 PM
2002 25' Safari
Dewey
Richard
06-16-2020, 07:27 PM
1977 31' Sovereign
Warman
, SK
My 77 sovereign door lock broke. Took it apart. The cam rod broke. Looking for replacement parts. Recommendations? I also am looking for replacement key cylinder. None in stock at the inland or Outdoorrv place. Any other suppliers?
