Old 06-25-2007, 09:44 AM   #15
calitrotter
1963gt's Avatar
Berkeley , California
and while we're on the subject...
when i got my 63 globetrotter, i did not have the keys for the locks on storage compartments..(or the door) i drilled the compartment locks out and removed them. went to my local locksmith shop and bought a matching set of locks that slipped right in. very common cam locks.
pretty cheap fix and very satisfying.
while we are on the subject of locks..
anyone know where i can get a replacement deadbolt for my rig.
i ordered a valterra rv deadbolt, but it doesn't fit without drilling and cutting, which i would like to avoid
i have seen the doorknobs set for sale, but i would like to get a deabolt.
i don't have a key for the top doorknob, but i took it apart and cleaned it, so it works well, just cant lock it.
thanks!
ID:	39850   Click image for larger version
mike
1963 Globetrotter OHIO
1988 Ford E150 Sportsmobile
2001 Buell X1 Lightning
2002 Isuzu Axiom 4x2
1963gt is offline   Reply With Quote
Old 06-25-2007, 10:20 PM   #16
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Originally Posted by Wayne&Sam
I don't know why one trailer needs four different keys to begin with. IMHO the best set up would be one key for all the compartments and dead bolt and a combination lock on the door.
I hear ya! Our 2002 Bambi even has a separate key for the fresh water door!
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 06-26-2007, 12:31 AM   #17
1992 34' Limited
Falls Church , Virginia
From an old AS hand....
Hello all -
Got an idea from an 'Old AirStreamin' Friend.... Take a set of keys that are dupes for what you need on the AS - put em on a small ring. Then go to you fridge compartment and reach WAAAYYYY up high in there on the side wall ( you pick which side) - install a small brass hook there. Voila!!! Keys when you need em!
I also did this with my 1 extra car key (to the TV) so if the whole shootin match goes away (robbery or whatever) I can still get outta dodge.... Also hung the house set as that is another potential 'loss' situation - that I am hoping to avoid.
Having em mounted up WAAAAYYYYYY high is to make the low bulb dummies ( the crooks) spend as much time to find them - if indeed they bother. It helps me know that if something horrible happens, at least I'll be able to enter my AS salvation with my key, and sleep the night.
Hope this thread and the comments will get you thinking - there are a zillion different ways to do this and I am sure that they run the gamut from cr*p to sensational. Find what speaks to you and then run with it.
Save yourself the trouble, agravation and not to mention the COST! of having locksmith come out and do your keymaking on site - drives the price up considerably!!!!!
Cutting a key at the shop might run $10 for a RV type key. Others maybe more. If you can, bring them the vrhicle with the 'problem lock' and it will be WAAAAYYYYY cheaper than calling them and having them come to you.
Hope that all this helps in some way!
Axel
SilverToy
SilverToy is offline   Reply With Quote
Old 06-26-2007, 06:34 AM   #18
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Smile
Expecting to lose my AS keys someday while camping I purchased a Shurlok ShurLok Key Storage Lock Box,key lock box,key lockbox,key safe,keysafe,key storage box,real estate lockbox and got dupes of all my trailer keys. The Shurlok holds about 6-8 small AS keys.
The dupes of all the AS keys at the local locksmith were $2 each. Ask your local AS dealer where they get keys and you will probably find they are not that hard to find locally or the locksmith will order the blanks for you.
So, for about $30 total I have access to a complete set of keys. You can find the Shurlok on eBay for about $21 including shipping and with the combo lock (you can set it to your favorite 4-digit number) no-one can easily get to your keys.
It worked for me.
SilverCottage is offline   Reply With Quote
Vote on lost key return service 66TradeWind Community Polls 12 05-01-2009 10:28 AM
Locked out of our exterior compartments...no keys Anna Exterior Storage Compartments & Access Doors 12 07-07-2008 10:20 PM
Airstream keys Pahaska Our Community 15 06-16-2005 09:03 PM
Lost Highway's 83Excella Link Archive 4 04-14-2004 04:00 PM
Trip report - Lost Maples SNA, TX Pahaska On The Road... 1 08-03-2002 09:28 AM
