Old 08-24-2011, 09:30 AM   #1
1972 29' Ambassador
Fayetteville , West Virginia
Key for water fill panel
My 72 Ambassador came with two door keys and nothing else. I had a local locksmith make keys for all of the exterior panels, but he ran into a problem with the water fill panel. According to him, this is some kind of proprietary key that he can't duplicate. He has picked the lock, and opened the panel, but can't make a key.
Can I get a key from the mother company or someone else, or can I get a new lock with a new key?
TJ
W.V. Stream is offline   Reply With Quote
Old 08-24-2011, 09:32 AM   #2
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
Check with Dan at" Out of Doors Mart " they should have a key
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 08-24-2011, 11:58 AM   #3
Two different locks, like wise keys were used.
Old 08-24-2011, 08:19 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
This PDF from Airstream says it's the same key that mine uses, the code is G248 and it's a double-sided Illinois key.
I bought mine from Out Of Doors Mart when local locksmiths were unable to help, they don't keep the blanks and/or don't have machines that can cut that key from a code.
Assuming yours uses the same key (Airstream's PDF says it does), it's $6.95 from Out of Doors Mart, here's the item.
David
12 volt panel location kmoore Electrical - Systems, Generators, Batteries & Solar 5 08-24-2011 09:45 PM
Fresh Water door Key texascanuk Fresh Water Systems 1 08-01-2011 12:16 AM
Hybrid fuse panel pgr32e Batteries, Univolts, Converters & Inverters 1 07-14-2011 09:56 PM
AC and DC Panel Meter Additions to WFCO RonMansfield Batteries, Univolts, Converters & Inverters 1 06-28-2011 12:51 PM
BoltLock: hitch reciever lock uses vehicle key Wayward Hitches, Couplers & Balls 1 03-18-2011 12:29 PM
